Author Topic: Welding sills?  (Read 2758 times)
Offline MickP mk3
Welding sills?
« on: 10 June 2013, 23:26 »
I need to do some welding on the passenger side sill on my 8vGTI up near the front wheel, is there anything inside the sill that i need to avoid before i start attacking it with the angle grinder (wires or anything).
Offline tweed
Re: Welding sills?
« Reply #1 on: 10 June 2013, 23:31 »
No but remove carpet etc
Offline MickP mk3
Re: Welding sills?
« Reply #2 on: 11 June 2013, 10:05 »
Super. yeah will do, thanks
Offline tweed
Re: Welding sills?
« Reply #3 on: 11 June 2013, 12:26 »
Disconnect the battery too
Offline sharki786
  • GOT BOOST??
Re: Welding sills?
« Reply #4 on: 11 June 2013, 13:24 »
Take interior out if you want it. Also keep a fire extinguisher next to you and someone watching out for any fire starting and wear the safety crap!!!
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline nike23naz
Re: Welding sills?
« Reply #5 on: 11 June 2013, 18:18 »
Keep 999 on speed dial!!!
Offline Screech16v
  • MK3 20vt AGU
Re: Welding sills?
« Reply #6 on: 11 June 2013, 18:50 »
Keep your glass/windscreen covered as spatter loves to burn in to it  :wink:
VW BUSH
Re: Welding sills?
« Reply #7 on: 11 June 2013, 20:13 »
Get a sill they are about £18+vat, use what you need.
Make sure you have some MS sheet 1.5 section to bridge the bits that aint there anymore :grin:
Just boshing some plate on will make the sill covers sit all pissed and wonky :wink:
As above, take the seat out and peal back the carpet and insulation it burns real quick, squirty bottles to hand to put out fires.
If its had waxoil squirted into the sills at some point this can also cause a problem with choking :laugh:
Offline Screech16v
  • MK3 20vt AGU
Re: Welding sills?
« Reply #8 on: 11 June 2013, 20:35 »
Good advise bushy  :smiley:
VW BUSH
Re: Welding sills?
« Reply #9 on: 11 June 2013, 20:52 »
:wink:
