Author Topic: Boost problem  (Read 1644 times)
Offline Gtijonesey
Boost problem
« on: 06 June 2013, 21:00 »
Hi I have had my gti for about 3 weeks and noticed when u accelerate u get boost and then about 3000 rpm I get a wooshh like a dump valve is going off but got a standard recric and loose boost if I keep my foot planted it picks up slowly. If I chance gear I get boost again than does same again. Any ideas anyone?
Offline mar_k
Re: Boost problem
« Reply #1 on: 06 June 2013, 21:08 »
Offline dom
  • Back in a Mk4
Re: Boost problem
« Reply #2 on: 06 June 2013, 21:25 »
Scanned for fault codes? Is it mapped?
Offline navmk4gti
Re: Boost problem
« Reply #3 on: 06 June 2013, 21:31 »
Look around for any splits in the boost pipes.
Offline Gtijonesey
Re: Boost problem
« Reply #4 on: 06 June 2013, 21:35 »
I keep getting engine man light on and coming on with lamda sensor. I got told its mapped but not to sure. It doesn't feel that fasted. I have had a look around pipes but canrt see out really.
Offline navmk4gti
Re: Boost problem
« Reply #5 on: 06 June 2013, 21:44 »
Then its most likely in limp mode
Offline Gtijonesey
Re: Boost problem
« Reply #6 on: 06 June 2013, 21:51 »
How would I know that mate get it plugged in?
Offline navmk4gti
Re: Boost problem
« Reply #7 on: 06 June 2013, 21:54 »
Yes scan it. Constant driving limp mode aint good. So if becomes obvious by the fault code what it is then sort it bud before cause damage other bits :wink:
Use rosstech faults code page bit description on what codes are
Offline Gtijonesey
Re: Boost problem
« Reply #8 on: 06 June 2013, 22:04 »
Cheers pal. I get lamda sensor sorted that's what I am getting. And fuel trim fault code not sure if that's something to do with lamda.
Offline budgie
Re: Boost problem
« Reply #9 on: 06 June 2013, 22:07 »
try not planting ur foot and try accelerating slowly,
