Author Topic: Doesnt start once hot  (Read 5029 times)
Offline jazz5000
« on: 06 June 2013, 16:46 »
Hi
Have a 1.4.
Car starts fine first time its started for the day, Then when driven and parked up it will fail to start.
When i put the key to the start position there is no cranking. Only way is to bump start the car or let it cool down for around 20 minutes.
Not sure if its a starter problem or a sensor. Any help here guys.
Offline rio_gti
Re: Doesnt start once hot
« Reply #1 on: 06 June 2013, 17:05 »
crank sensor?
Offline jazz5000
« Reply #2 on: 06 June 2013, 20:01 »
Just scanned it with vagcom:
2 Faults Found:
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
            P0420 - 35-00 -  -
16712 - Knock Sensor 1 (G61): Signal too High
            P0328 - 35-10 -  -  - Intermittent
Readiness: 0000 0000
Would this mean the crank sensor?
jamie16v
« Reply #3 on: 06 June 2013, 22:16 »
2 Faults Found:
            P0420 - 35-00 -  -
it`s KNOCK sensor, not a good thing really, are you mapped? what fuel are you running?..
the non starting issue could be due to a sticky starter motor solenoid.. you need a new starter by the sounds of it.
Offline jazz5000
« Reply #4 on: 07 June 2013, 06:39 »
No not mapped as its a 1.4 :cry:
Just running regular supermarket fuel
jamie16v
« Reply #5 on: 07 June 2013, 10:52 »
not starting once warm sounds like a coolant temp sensor tbh..
also supermarket fuel isnt the best for knock control.
delete the codes, and see what comes back!
Offline SI74
« Reply #6 on: 07 June 2013, 12:13 »
I would go with along the lines of coolant temp sensor of the fuel one.
Offline xxChrisxx
« Reply #7 on: 07 June 2013, 12:29 »
Not cranking? Starter.
The fact that it bumps means the fuel and spark is ok. Try belting the solenoid with a mallet.
Also the knock is not the fuel you are using. The 1.4 is pretty agricultural as far as engines go and 95RON is 95RON is 95RON. So buying Shell fuel save, or Tescojuice, it'll have basically the same knock characteristics. As it all has to meet standards, or it can't be sold, in many cases it'll be the same fuel stock. The difference is lubrication and other assorted additives.
With a signal too high code, it's more likely that you've got a broken knock sensor/wire.
« Last Edit: 07 June 2013, 12:34 by xxChrisxx »
jamie16v
« Reply #8 on: 07 June 2013, 13:36 »
i stand corrected, didnt read the bit where he said it`ll bump start..  sticky solenoid, and i also agree with the knock sensor wire.
Offline jazz5000
« Reply #9 on: 07 June 2013, 15:49 »
Thanks for replies,
I have changed the coolant temperature sensor last month as i used to never get a reading on the clocks before.
When i try to start once its warm it does slightly crank very slowly and after around 3-4 tries it stops cranking.
Also where is the knock sensor located so i can investigate
Thanks
