Author Topic: Doesnt start once hot  (Read 5014 times)
Offline jazz5000
Re: Doesnt start once hot
« Reply #30 on: 17 June 2013, 18:35 »
hasn't given anymore trouble since in the same circumstances. So i hope so  :laugh:
Offline jazz5000
« Reply #31 on: 18 June 2013, 22:30 »
Had same problem again,
So fitted a new battery.
So far so good
jamie16v
« Reply #32 on: 18 June 2013, 22:38 »
I stand correct... haha  :cool:
Offline jazz5000
« Reply #33 on: 02 July 2013, 12:46 »
Starting to have the same problem again.
Could it be a alternator problem?
As the battery sorted it for a while. So im thinking the battery is not getting charged enough.
However voltage is 14.2v when running etc
Offline gazareth
« Reply #34 on: 02 July 2013, 22:40 »
hi next time it does it try a pair of jump leads hooked up to another fully charged battery. if it fires straight up then you know the problem aint the starter anyway. is the engine overheating by any chance?
Offline jazz5000
« Reply #35 on: 03 July 2013, 21:26 »
Last time it happened I jumped started it and it started straight away .
This is why I changed out the battery.
Don't think car is overheating . sits at 90. Sometimes less .
Happened last time once I did a drive on motorway. Rpms were at 5k so was probably running hot
Offline Rhyso
« Reply #36 on: 04 July 2013, 10:00 »
Temp gauge should sit bang on 90; so sounds like you got a thermostat problem
Also what speed where you doing for your RPM to be sat at 5k?? :shocked:  Or were you driving around in 3rd gear??
Offline jazz5000
« Reply #37 on: 08 July 2013, 14:49 »
Went to a garage to do a load test on battery,
They said battery is good.
The alternator is the problem. It is not giving enough voltage to charge up the battery.
Would a 150A alternator go straight in?
Offline jazz5000
« Reply #38 on: 20 July 2013, 16:15 »
Fitted a 180A alternator in.
Very happy with the voltage now.
Previously dropped to 11.5v with heater/headlight/rear demister/bass on full/air ride compressor
Now it does the above and doesn't go below 13.5v.
Will do the big 3 tomorrow aswell
