Author Topic: problem nearly solved  (Read 1424 times)
Offline matty james
« on: 06 June 2013, 16:43 »
following on from my last 2 posts,can anybody answer me this question? my car wont start because my fuel pump keeps blowing the 15amp fuse in the fuse box, due to the pump probably drawing to much power. does this mean the fuel pump relay is faulty rather than the fuel pump itself ? i can hear a humming noise coming from the back end of the car > this i think in all probability is the fuel pump , its to much of a coincedence not to be. any answer greatfully recieved  :smiley:
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline GTi_James
Re: problem nearly solved
« Reply #1 on: 06 June 2013, 16:56 »
replacement fuel pump? if its that causing the fuse to pop then may be the culprit
Offline matty james
« Reply #2 on: 06 June 2013, 17:03 »
knowing my luck bud  thats what it will probably be  :sad: but still hoping its a faulty pump relay, that could cause the fuse to pop, hoping somebody could tell me before i buy a relay to pop in and see if that cures the problem  :whistle:
Offline GTi_James
« Reply #3 on: 06 June 2013, 17:26 »
that would be the cheaper option, and if it is the pump then atleast you get 2 nice new shiny bits lol
Offline matty james
« Reply #4 on: 06 June 2013, 21:52 »
how bigger job is it to change a fuel pump? and wot price for apump? as im quite handy bloke wid a spanner in my hand , im a design and tech technician lol :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 06 June 2013, 22:43 »
Pump takes about half hour to change. Also if you get a second hand one they are the same for the 1.4,1.6,1.8
Offline matty james
« Reply #6 on: 06 June 2013, 23:02 »
so not to hard to do then? what price roughly am i looking at for a new pump ?
Offline pickles
  • Next!!!
« Reply #7 on: 07 June 2013, 12:28 »
bout £75.60 with discount at ECP
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline pickles
  • Next!!!
« Reply #8 on: 07 June 2013, 12:31 »
just noticed  ReadieeVTS has one for sale in classifieds for £30, for an AGU tho
Mapped
Nearly S3 time  :)
Offline matty james
« Reply #9 on: 07 June 2013, 15:06 »
cars running again at moment ,without changing parts,i pulled the fuel pump relay out and plugged it back in last nite and it starts up ok, done about 50 mile today and starts ok, so idont know whats caused it , my pal gave me a new relay to use but havent used cos my is working fine at mo. so its a bit of a head scratcher :undecided: :undecided:
