Author Topic: Injector seals  (Read 1663 times)
Offline ian007miles
Injector seals
« on: 02 June 2013, 16:57 »
Does any one no were I can get injector seals for a 18t agu. Coz I've got a slight smell of petrol wen I excelorate and around the injectors are abit wet looking so think that's where it's coming from but if any one else has any suggestions that would help thanx
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Injector seals
« Reply #1 on: 02 June 2013, 17:45 »
You mean the rubber o rings? Ebay if so
Offline Scott-R
  • GoT BoosT!
Re: Injector seals
« Reply #2 on: 02 June 2013, 18:02 »
Flea-bay.
Golf GTI ... What else would you have?
Offline ian007miles
Re: Injector seals
« Reply #3 on: 03 June 2013, 00:00 »
You got any links mate the only ones I can find are for the 19 deisels
Offline pickles
  • Next!!!
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline brewey
Re: Injector seals
« Reply #5 on: 03 June 2013, 19:09 »
You might find that it's the metal seats and not the rubber o-rings. The original sealant may have perished and now when you're on boost some fuel is coming up the threads.
2000 1.8T ARZ - OEM+
Offline ian007miles
Re: Injector seals
« Reply #6 on: 03 June 2013, 20:18 »
how hard is that to rectify?????
Offline brewey
Re: Injector seals
« Reply #7 on: 03 June 2013, 22:31 »
Its an inlet manifold off job not sure on how difficult it is to do though other than that. I need to do it to mine at some point as I have a similar issue although at the minute it isn't as bad as yours sounds. However I'm sure there is a guide in the maintenance section somewhere.
I think that Wazzer also explains the process in his build thread.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Injector seals
« Reply #8 on: 04 June 2013, 14:42 »
I do indeed, part numbers are also there
Offline rio_gti
Re: Injector seals
« Reply #9 on: 04 June 2013, 15:17 »
is it only a manifold off job because tiny bits of the sealent may drop into the block??
