Author Topic: cold air feed & heat sheild  (Read 3951 times)
Offline Scott D
« on: 01 June 2013, 20:41 »
changed to an S2000 cone filter but due to the size couldn't fit the heat sheild that was previously on. a lot of brute force and a hacksaw managed to get it on and a slightly pikey cold air feed from the lower grill using a cone trumpet I think from the original air box.
seems to be working very well, filter still felt cold after a long drive and 247bhp on a 3rd gear run using liquid guage - questionable accuracy but worth the hour of DIY  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline dom
  • Back in a Mk4
Re: cold air feed & heat sheild
« Reply #1 on: 02 June 2013, 21:33 »
I've got an s2000 filter and heat shield waiting to go onto mine, what did you use for cold air feed?
Offline navmk4gti
« Reply #2 on: 02 June 2013, 23:35 »
What have you got over the head shield?? Mine should be coming soon then will put my pipercross cone filter kit in :cool:
Was goin to just do my heat shield matt black but dont want to be boring :grin: is yours powder coated?
Offline Scott D
« Reply #3 on: 03 June 2013, 19:28 »
3" neoprene hose of flea bay
used heat reflective tape on the shield, probably makes no difference but looks bling  :grin:
Offline navmk4gti
« Reply #4 on: 04 June 2013, 09:50 »
U have a link to the heat reflective tape bud :smiley:
Offline Chris#101
« Reply #5 on: 04 June 2013, 10:18 »
Has anyone.got a link to these s2000 filters, there massive  :cool:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Scott D
« Reply #6 on: 04 June 2013, 16:12 »
found both on ebay cant remember which sellers
can get from any ECP although will be different colour, blueprint make the black & red coloured filter
Offline paultownsend
« Reply #7 on: 04 June 2013, 18:31 »
There £14 of so from ECP. Have to get a 70mm-86mm reducer to fit on a 70mm MAF.
Took mine off as it was stupid induction loud.
I was embarrassed.
Children jumped into bushes with the fear of being sucked in.
« Last Edit: 06 June 2013, 08:08 by paultownsend »
Offline Dalo Harkin
« Reply #8 on: 06 June 2013, 00:01 »
There £14 of so from ECP. Have to get a 70mm-86mm recover to fit on a 70mm MAF.
I was embarrassed.
Children jumped into bushes with the fear if being sucked in.
Gotta get one just based on the last sentence lmao
« Reply #9 on: 06 June 2013, 11:04 »
Agreed, I was not keen when I tried the same set up.
