Poll
my car is drinking fuel!!!!!!! any ideas?????
fuel
0 (0%)
problems
1 (100%)
Total Members Voted: 1
Author Topic: fuel problems  (Read 1193 times)
Offline hayl1984
fuel problems
« on: 26 May 2013, 22:44 »
hi all i think my car has a fuel problem  :angry:
its absolutely drinking fuel!!!!!!!! - i havnt filled it yet but i put £20 in and am only getting about 60mpg which is terrible  :sad:
does anyone have any clues on what it could be??????  :huh:
any ideas welcome as getting very desperate as cant afford to run it for much longer!!!!!!!
thanks  :smiley:
jamie16v
Re: fuel problems
« Reply #1 on: 26 May 2013, 22:49 »
if my car did 60mpg i would be very, and i mean VERY happy!
what engine do you have, get it scanned for faults would be your first step. that`ll lead to clues to if you have a problem!
« Last Edit: 26 May 2013, 22:51 by jamie16v »
Offline Nino
Re: fuel problems
« Reply #2 on: 26 May 2013, 22:53 »
60mpg!!!  :shocked: :shocked:
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Rockey5uk2001
Re: fuel problems
« Reply #3 on: 26 May 2013, 22:55 »
my diesel mg dosnt even do 60mpg! my golf does 37 in the city not taken on a run yet
Offline dom
  • Back in a Mk4
Re: fuel problems
« Reply #4 on: 27 May 2013, 08:30 »
I hope that is a typo because any mk4 engine would be doing well to get 60mpg!
Re: fuel problems
« Reply #5 on: 27 May 2013, 20:24 »
More info needed, year, engine and spec would all help :smiley:
Offline navmk4gti
Re: fuel problems
« Reply #6 on: 27 May 2013, 20:31 »
If your getting 60mpg ill buy your mk4 now  :grin:
Offline hayl1984
Re: fuel problems
« Reply #7 on: 27 May 2013, 22:51 »
hi thanks for the replies sorry i have just read my post as it was misleading it does 60 miles to £20.00 which is just under half a tank!!!! so not very good at all
its a 2.0l gti 8v on a 2000 plate, its been on the diagnostic iv had the lambda sensor replaced so my fuel is now slightly better
iv only had the car for 2 weeks and looking through the paperwork i found an invoice for a super chip so now im not sure what bhp it is???? which im sure is not helping with my fuel
thanks all
jamie16v
Re: fuel problems
« Reply #8 on: 27 May 2013, 23:35 »
super chip on a 2.0l 8v seems a bit pointless, i would see if you could obtain a second hand ecu from somewhere and see if someone is kind enough on here to code it in for you.
I reckon the "superchip" may be causing it to use excessive fuel for not alot of gain.
i could be totally wrong in saying that mind you. also i think the 2L8v engines are not the most economical of the bunch.
Re: fuel problems
« Reply #9 on: 27 May 2013, 23:50 »
I would get it scanned for fault codes as a 1st step, then look to replace the temp sender also as Jamie said it may be worth going back to a standard ecu.
