Author Topic: can anyone help  (Read 2670 times)
Offline jynx288
can anyone help
« on: 08 August 2005, 13:20 »
hi all i have a 1992 clipper to which i have installed what i think is some pretty impresive ice head unit is a kenwood KVT 920dvd with a ten disc changer and sat nav also 2 kenwood amps being a KAC 849 600 watt 4 channal amp and a KAC 929 1000 watt running a JBL 1002D sub with jbl components front and rear my problem is that the bass keeps dropping out when i turn it up quite loud :cry: do u think a higher ampage alternator would sort my problem if so what other VW alternators would fit :huh:
« Last Edit: 09 August 2005, 11:10 by jynx288 »
Offline Len
Re: can anyone help
« Reply #1 on: 09 August 2005, 13:50 »
Power is your problem. You dont say if your main feed is direct off the battery. If not try that first.
If that doesnt solve it then you need to look at these cap things.
Not too up on these things coz I'm not into that much power! But sure you could check it out on 'net
Power Capacitor things - they store power to cope with the peaks, which is why yours keeps tripping out!
Alternatively turn that big volume knob down and save your ears! :laugh:
« Last Edit: 09 August 2005, 13:52 by Len405 »
www.sas.org.uk
www.the-ace.org.uk
Offline jynx288
Re: can anyone help
« Reply #2 on: 11 August 2005, 11:59 »
cheers len i think a power cap will be needed but i think my main problem was that i had blown the sub to bits :huh: but luckily the shop was good enuf to change it for a new 1 :smiley:
Offline 1 Lp
Re: can anyone help
« Reply #4 on: 14 August 2005, 13:56 »
U don't have to add a power cap, it cud be u have a weak battery! a power cap is a good way to go, but check ur battery is up to the job first a power cap cud coz u more problems.
Also check ur using the correct guage wire, is ur using 8 guage forget it. Kenwood amps like 4 guage, or if u don't have budget 0 guage wire but it cost around £10 per metre and u need 5 metres!
 :wink:
VWs are like women, they need love care and attention
Judderi
Re: can anyone help
« Reply #5 on: 15 August 2005, 09:37 »
Ive decided to give one of these a go.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=5796132495&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
They seem like a no frills quality alternative. The same company also sell 0 guage wire allot cheaper than £5 per meter!
« Last Edit: 15 August 2005, 09:39 by Mk2GTI2.016v »
Offline Barnie@4d
Re: can anyone help
« Reply #6 on: 15 August 2005, 15:11 »
power caps are cráp
batcaps are good though
first upgrade should be the big 3 especialy in older cars, cheap and actualy a very effective upgrade
Judderi
Re: can anyone help
« Reply #7 on: 15 August 2005, 15:14 »
whats the big 3?
Offline Barnie@4d
Re: can anyone help
« Reply #8 on: 15 August 2005, 15:36 »
TB3 or the big 3 is a must when installing,
The Big 3 Are:
1. negative battery wire to ground - just replace the negative batt. terminal and wire and ground it to the factory location
2. engine block to ground - replace the ground wire from the engine block to the chasie with a bigger wire (maybe 4 guage)
3. alternator to batt -hope thats helps
Judderi
Re: can anyone help
« Reply #9 on: 15 August 2005, 15:40 »
I see. I would normally do 2 out of that 3. Never thought of the ground wire for the engine, good idea.
