Author Topic: DV issue?  (Read 1921 times)
Offline Dalo Harkin
DV issue?
« on: 22 May 2013, 22:38 »
Hi guys,
Just a quick one, I was out in the golf last night and when giving it some when lifting off the throttle the DVD sometimes dumps 2-3 Times in quick succession.... any ideas ?
DV is forge 0007p with yellow spring
jamie16v
Re: DV issue?
« Reply #1 on: 22 May 2013, 22:44 »
is the vac hose to the dv leaking at all?..
Offline Granta Gti
Re: DV issue?
« Reply #2 on: 22 May 2013, 22:46 »
Did you lift off fully or slightly?
Offline Dalo Harkin
Re: DV issue?
« Reply #3 on: 23 May 2013, 09:09 »
no
Offline Dalo Harkin
Re: DV issue?
« Reply #4 on: 23 May 2013, 09:09 »
only seems to happen when you partially lift off
jamie16v
Re: DV issue?
« Reply #5 on: 23 May 2013, 09:13 »
what spring do yo have fitted?
Offline Nino
Re: DV issue?
« Reply #6 on: 23 May 2013, 11:26 »
sounds like a leak or weak spring is your car remapped?
Current - MK6 GTi Edition 35
Offline Dalo Harkin
Re: DV issue?
« Reply #7 on: 23 May 2013, 12:29 »
definitely not leaking, yellow spring as its stage 2
Offline rio_gti
Re: DV issue?
« Reply #8 on: 23 May 2013, 12:34 »
stage 2 shouldnt that be blue spring? i put a blue spring in mine and im only on stage 1 and it feels alot more responsive!!!!
Offline Dalo Harkin
Re: DV issue?
« Reply #9 on: 23 May 2013, 12:58 »
depends who you ask  :rolleyes:
Blue is only just borderline for my stage 2 - you're massively resisting yours with a blue Rio
