Author Topic: leak in boot odd though....  (Read 1613 times)
Offline davemk4
« on: 21 May 2013, 21:52 »
Spotted other day pool of water in my boot. It in far left corner below rear light in line where the webbingvis and drain bung id. Whats odd is all around light boot seal etc bone dry. It leaks when car parked up too sobit not a movement leak. Is this a common place on the mk4? Also checked washer pipe andvthat all intact
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline SI74
Re: leak in boot odd though....
« Reply #1 on: 21 May 2013, 22:21 »
Where did you check the washer pipe? Where it comes through from the car and behind the cover on the boot itself?
Does it get worse if it rains?
Offline GunnerCP
« Reply #2 on: 21 May 2013, 22:29 »
I had a leak in the boot once, it was coming through the aerial base but somehow no marks on headlong, c pillars etc..... Not quite the same location as yours as mike was more drivers side, worth a look though if the seal has perished.
There's a vent filter thing under the bumper that also breaks down but if its like that from being stationary I don't think that'd be applicable in your case.
Offline davemk4
« Reply #3 on: 22 May 2013, 06:23 »
Behind the cover we checked. The odd thing is the insulation sll around the light and washer pipe etc dry. It litterally wet at the bottom where the air vent and drain bung is. The airvent it self drybtoo. No water mark any where
Offline SI74
« Reply #4 on: 22 May 2013, 07:30 »
Is the 3 nuts holding the light in tight?
Offline mcgee9t2
« Reply #5 on: 22 May 2013, 12:47 »
take the boot liner our, get a mate to climb in the boot, shut door, put hose on the car and see if he can see water coming in...
id guess that its the big drain... may look dry but i belive its rubber so water will just roll off it leaving it looking dry.
Offline davemk4
« Reply #6 on: 22 May 2013, 14:17 »
Ill try that me dad suggested this too. Ill update tommorow ta
Offline mar_k
« Reply #7 on: 22 May 2013, 22:00 »
Seal around the air vent will have perished most likely.
Offline davemk4
« Reply #8 on: 22 May 2013, 22:11 »
find out tommorow  :grin: im going to climb into me boot and missus to hose pipe the car
Offline davemk4
« Reply #9 on: 23 May 2013, 20:00 »
so climbed into boot........ hose pipe on car and found it leaking through bottom of the breather air vent. trickles in over time. so having a look with bumper off later in week, trying to think how it leaking there what behind it etc
