Author Topic: anybody ever fitted WMI with a k03 turbo... also a turbo question  (Read 3830 times)
Offline mcgee9t2
anyone?
current set up I have 3" dp. full exhast system. decat. induction kit (soon to be replaced with panel filter when I can be bothered) fmic. hoses. diverter valve. all the usual.
long term I want to fit a k04-001 turbo and run wmi. however wmi is more fisable at the moment, turbo further towards the end of the year.
so question is... has anyone with a k03 turbo (not k03s) fitted wmi?
what would you expect from the above set up with wmi? 200bhp? is it worth me doing or should I just buy the wmi and not fit until I have a the k04-001..
also out of interest anyone ever hybridded a k03 and k03s togeather? would there be much point? don't think the k03s is that much bigger so never really thought about it until right now and cant see there being much point cause the k03s isn't really big enough to give much lag like you get fitting bigger turbos. if anyone has hybridded a k03 and k03s... what were the results?
Offline brewey
Are the K03 and k03s not the exactly the same housing with different turbines? There's a guy called litco on here that makes hybrids that are direct fit that push either 270 or 300 with the right supporting mods.
2000 1.8T ARZ - OEM+
Offline mcgee9t2
Note that I will be getting a map after fitting wmi or turbo.
And not sure. Could be something to look into. If so I'd happily take the turbo off recon it and replace the turbine.
I always thought it was the turbine houseing is the same. But haven't really looked into it so you could be right.
Offline jonrandom
As said the k03, k03s, k03/s hybrids are the same housing wise but with different turbines. It would be better to get it mapped to include WMI but if your going to get a k03s then wait and get it all mapped together. WMI can be run without mapping but like with anything much better off getting it mapped in
Offline shaft69
Wmi personally was awesome on my mk4, running wmi on my BMW 330d now brill. I set my wmi on mk4 myself with vagcom and lemmiwinks. If now what to do, do it yourself not hard enough people around to help. Also found big difference with maf  wmi controller over hobs switch type.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Toby
  • Car - less
Nik from r tech is about to map a ko3 hybrid with hopes of safe 330bhp  :laugh: :laugh: :evil: :evil:
Currently down under
jamie16v
k03 and k03s have the same turbine, the compressor is a bit larger on the k03s.
a k04-001 has a larger turbine than the k03 and k03s but i think the compressor is slightly smaller than the k03s. you would be better off hybriding the k04-001 with a k04-023 compressor but that needs modification of the compressor housing. as said, littco can make the hybrids and he can get the housings made up easy enough.
i went down the easy route and bought a chinese k04-001, but its not a k04-001, it has complete k04 sized internals. simular to the E05 hybrids you hear about. if and when it fails i know i can just get a genuine k04-023 and fit the cartridge into the housings after an overhaul.
i plan to buy WMI kit next then go for a custom map when cash allows..lol
Offline Dave_IOW
See this come on late last night, interesting :laugh:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
jamie16v
got a link?  :whistle:
Offline mcgee9t2
yeah i noticed that k03 with different internals made by the guys a few workshops down from rtech a belive??
could be interesting...
however i dont think ill be going that high, dont want to start replacing rods etc so proberbly only going to try acheive 240-250 bhp in the long run
