Author Topic: Easiest way to take out 1.8t engine out?  (Read 1779 times)
Offline Chris#101
« on: 20 May 2013, 18:53 »
Howdo :smiley: got my replacement engine to fit and was wondering what was the easiest way to take it out?
I've got access to a set of lifting ramps, so my theory was to drop the engine and gear box still attached to the subframe on the floor, lift car up then fit new engine and reverse steps?
What have others done? :smiley:
Thanks
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline jonrandom
Re: Easiest way to take out 1.8t engine out?
« Reply #1 on: 20 May 2013, 20:01 »
Id say your better off dropping the subframe getting it out of the way along with the driveshafts. The whole front end comes off pretty easy so just crane it out the front.
Offline mcgee9t2
« Reply #2 on: 20 May 2013, 23:08 »
that's how ide of thought it would be easiest taking it out the front rather than below... chances are your going to take the bumpers etc off for access anyway.
Offline rio_gti
« Reply #3 on: 20 May 2013, 23:29 »
This is by far easier..... And quicker
http://m.youtube.com/watch?v=e5MZcxZdZdw
Offline shaft69
« Reply #4 on: 21 May 2013, 22:17 »
Hahaha golf 20vt is pretty easy try doing it in Audi TT twice the job.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 21 May 2013, 22:29 »
Offline mar_k
« Reply #6 on: 22 May 2013, 21:01 »
Having recently done this, We whipped the front end off,
Undone both the drive shafts at the flanges, disconnected everything and pulled it out the front.
Didn't touch the subframe at all.
« Last Edit: 22 May 2013, 21:07 by mar_k »
jamie16v
« Reply #7 on: 22 May 2013, 21:33 »
haha,, brilliant.. was half expecting that though  :grin: :grin: :laugh:
Offline brianpologti
« Reply #8 on: 23 May 2013, 13:04 »
As above , u can pull the front off , easier to get to connects etc etc
