Author Topic: drunk far too much and lost my key! Update  (Read 3599 times)
Offline mrsaunders
« on: 19 May 2013, 17:28 »
basically ive lost my only key and cant get into my car  :cry:, just want to know my options as it has a factory fitted conlog something, i know vw can cut me a new key and chip but what about conlog fob thing!
looks like last night was one expensive night for me!  :angry:
« Last Edit: 21 May 2013, 08:19 by mrsaunders »
Offline nhop10
  • Mk3 GTi
Re: drunk far too much and lost my key!
« Reply #1 on: 19 May 2013, 18:17 »
im in a similar situation, lost my only key to mine last week, its also got an after market clifford alarm on there.
i called out an auto locksmith who got me a key that works for the locks, but no immobiliser chip, as couldnt program one to it cos the alarm was going off. so i just disconnected the battery to stop the alarm going off for the meantime.
i am gunna have to try and get an alarm guy to come out and take it out properly then get the key guy to come back and hopefully programme an immobiliser chip to it so i can actually use it again. although he aid he might not be able to do it cos of the age of the car, and might have to send the immobiliser box off for a week with the new key. so im not sure what i would do if thats the case. all a bit complicated and bloody irritating! tax out at the end of the month and mot soon, not good.
Mk1 Golf 1.1, 6n Polo 16v, and now an 8v mk3 GTi
Offline mrsaunders
« Reply #2 on: 19 May 2013, 19:23 »
How much was you quoted roughly?
Offline itavaltalainen
« Reply #3 on: 19 May 2013, 19:24 »
if you still got the login code (small plastic tag that you'd get with the keys when you buy a car new, maybe VW can request this for you also) you can get the keys recoded
alarm you can probably just disconnect and bring back to original state (you'll see where wires were cut etc).
Offline mrsaunders
« Reply #4 on: 19 May 2013, 19:35 »
My alarm come as an optional extra i think, how would I go about disconnecting that?
« Reply #5 on: 19 May 2013, 19:42 »
My old Golf also had an alarm - horn under the bonnet, electronics box connected up in the central electrics section, the control unit sat above the central electrics.
take off fuse/relay box cover, undo the two small pieces of trim under the steering wheel, then undo the screws (i think there's 5 or 6 philips heads) then take the bottom dash trim off (Will fall off after undoing the screws).
Then look up over central electrics box and follow the wires. it will become reasonably clear what to disconnect and where you have to reconnect wires that were cut and the alarm set in series.
Offline mrsaunders
« Reply #6 on: 19 May 2013, 19:49 »
Thanks, I'll give it a try during the week
Offline nhop10
  • Mk3 GTi
« Reply #7 on: 19 May 2013, 21:09 »
i have looked at my alarm before, there a control unit under there is it as simple as just desplicing the wires where they have been joined?... but arent some alarms connected up to the fuel pumps or other things to stop the car from starting if the alarm if attempted to be broken? not that i think my alarm has a particularly complicated system  :huh:
Offline mrsaunders
« Reply #8 on: 20 May 2013, 11:05 »
If I was to get a new conlog/logic 900 fob is there a way to program it to my old control box?
Offline mrsaunders
« Reply #9 on: 20 May 2013, 11:07 »
Or is there a guide to remove my alarm? It's wired into my CD player aswell, never been to good with wires  :undecided:
