Author Topic: quick cd player change question  (Read 956 times)
Offline davemk4
« on: 18 May 2013, 19:06 »
as my oem one playing silly buggers. i just want a normal straight non flash upgrade unit.
will this work all ok play copied cds etc
http://www.ebay.co.uk/itm/VW-Golf-MK4-CD-MP3-player-Kenwood-car-radio-plays-iPod-iPhone-Front-AUX-in-/181078931653?pt=UK_In_Car_Technology&hash=item2a292538c5
 :smiley:
mine  a 2001 mk4
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline tallpaulr
Re: quick cd player change question
« Reply #1 on: 18 May 2013, 19:43 »
Should do, I had a Kenwood for years before I went to Alpine for my Ipod. It played all my copied discs and then some.
Offline davemk4
« Reply #2 on: 18 May 2013, 19:55 »
it all seems ok plus it comes with all the right wiring for the mk4 not bothered about amps etc as long as it holds the same sound quality as oem im happy
jamie16v
« Reply #3 on: 18 May 2013, 20:22 »
the good thing about the oem radio i believe is it has been tuned to match the acoustics of the car. not a powerful unit or anything but is well matched to the standard speakers and car acoustics..
correct me if i`m wrong but i`m sure i read that somewhere.
if i were to change the head unit for anything else i would also change the speakers. but that means buying speaker pod adapters too..
Offline davemk4
« Reply #4 on: 18 May 2013, 20:43 »
never simple is it lol. i just want to sort my cd issue out grrrrrrrrrrrr. there seems no defo answer unless i change to after market
Offline dom
  • Back in a Mk4
« Reply #5 on: 18 May 2013, 20:46 »
Standard speakers in a MK4 are surprisingly good, you should notice an improvement with that head unit. Is yours only a single DIN unit at the moment?
Offline davemk4
« Reply #6 on: 18 May 2013, 20:58 »
it got cd player at top then middle is tape take and main control unit radio etc then bottom got climate control.
