Author Topic: Lowering springs help!  (Read 3741 times)
Gavv8
Re: Lowering springs help!
« Reply #10 on: 16 May 2013, 19:16 »
the -60mm will be from a std golf (not gti) so they will be 40/45mm in real life
only quality (eibach) list true lowering and people moan saying -20mm is not enough (then go and buy -40mm apex etc)
oh and i would go for gti springs (95+ 65mm pig tails)
'Pi' also do shortened shocks quite cheaply, a full set of shocks and springs are about £240.. i've no idea about the quality but they can only be an improvement over old worn out gear.
Offline stainesy
« Reply #11 on: 16 May 2013, 20:13 »
Paul just use your koni's for now and when and IF they die then just buy some shortened ones.  :wink:
Offline Len
« Reply #12 on: 17 May 2013, 12:46 »
What you actually need is uprated shocks, but as you have Koni's already they will be fine.
www.sas.org.uk
www.the-ace.org.uk
« Reply #13 on: 17 May 2013, 13:12 »
Even Koni sport shocks are only designed for -20mm springs, 60mm drop will need shortened shocks that are designed to work with the shorter travel.
Offline dom
  • Back in a Mk4
« Reply #14 on: 19 May 2013, 19:48 »
This. The extra strain you're putting on the shocks will mean they'll fail prematurely.
