Author Topic: Lowering springs help!  (Read 3740 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 15 May 2013, 22:41 »
I am looking at some lowering springs as in a 60mm drop as I already have spring/shock setup but springs are only a 20mm drop.  I have seen a few lowering sprins on Ebay saying they are 60mm drop but the majority of ad's are saying 'Golf MK3 8v'  'Golf GTI 16v'  My Golf was originally a VR6, do I need VR6 springs or would GTI 8v or 16v springs be ok?
Re: Lowering springs help!
« Reply #1 on: 15 May 2013, 23:51 »
To run a 60mm drop would mean changing the shocks as well.
8v/16v will be fine for yours with the 1.8t
Offline gasketface
« Reply #2 on: 16 May 2013, 01:27 »
Make sure you get the correct fronts for your year as the internal diameter was changed around 95 i believe so if you get the wrong one's your top caps wo'nt fit and you will be stuffed until you either get the right sized caps or the right springs
Gavv8
« Reply #3 on: 16 May 2013, 05:57 »
You can go -40mm on standard shocks but you'll need shortened shocks for a -60mm drop as standard ones won't last very long.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #4 on: 16 May 2013, 10:33 »
This is interesting. So the shocks wont be very happy with a 60mm lowering springs on them?  Does it help that they are Koni shocks so should or maybe be able to take more of a pounding than say standard shocks?
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 16 May 2013, 11:52 »
the -60mm will be from a std golf (not gti) so they will be 40/45mm in real life
only quality (eibach) list true lowering and people moan saying -20mm is not enough (then go and buy -40mm apex etc)
oh and i would go for gti springs (95+ 65mm pig tails)
« Reply #6 on: 16 May 2013, 12:02 »
Nope you will need shortened shocks.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #7 on: 16 May 2013, 12:16 »
Oh.....I see, thanks Wayne.
So the lowest I can go is 40mm on my shocks, hmmm, wonder if it is worth it as she has a 20mm drop already?  I like the idea of coilovers but to get a 'good' ride you need to spend a fair few quid as the Ebay ones give a very hard ride and are not that good from what I understand?
Offline ttelracs
  • The Fettler
« Reply #8 on: 16 May 2013, 12:20 »
I agree with the shortened shocks, ideally matched to the springs as you'll literally kill the shocks within a few hundred miles.  But, I have some 40-50mm lowering springs from some JOM shocks I fitted a couple of months ago which you are welcome to.  PM me if interested and I'll charge you postage plus a drink or you can collect from the Harrow area.
Offline Len
« Reply #9 on: 16 May 2013, 13:19 »
Not necesary to change the shocks especially as you have Koni's.
Lowered the rear of my Pug without fitting shorter shocks and have done thousands of miles like that.
www.sas.org.uk
www.the-ace.org.uk
