Author Topic: Rear Brakes  (Read 1190 times)
Offline hockeylad72
Rear Brakes
« on: 07 August 2005, 10:54 »
Hi guys,
need some help again!
I bought rear calipers and trying to fit them was a real pain, the handbrake cable goes in a different way so I would think I would need handbrake cables that are a bit longer? does this sound right? bought the calipers really cheap so might be worth spending a few bob on new handbrake cables
any help or advise would be appreciated
cheers
Offline dubslug
Re: Rear Brakes
« Reply #1 on: 07 August 2005, 12:48 »
i think the early models need longer cables but i could be wrong, sorry not very helpfull really
1992 pearl grey 8v
Re: Rear Brakes
« Reply #2 on: 07 August 2005, 15:10 »
Think somewhere in the region of 87/88 the cables changed, not sure exactly what year.  Dubslug is correct though, the earlier cables were shorter :)
Easy to convert between them though, if early buy early cables, if late buy the late cables.
Offline bretttuk
Re: Rear Brakes
« Reply #3 on: 07 August 2005, 18:08 »
What rear calipers did you buy ? if you bought mk3 ones or later mk2 ones 89 onwards ( i think ) , you will need the longer handbrake cables ... about £8 each (you'll need two) ... from Eurocarparts.
Easy (ish) job... just a bit fiddly.. easier job if there are 2 of you ..
Offline hockeylad72
Re: Rear Brakes
« Reply #4 on: 11 August 2005, 23:22 »
dubslug you were right, got it sorted today its great being able to park anywhere without worrying about handbrake seizing on!
thanks again for your help guys
