Author Topic: any DJs in here?  (Read 2813 times)
Offline davemk4
any DJs in here?
« on: 10 May 2013, 22:52 »
im after some advice. i REALLY want to learn the basics of mixng music etc not for pro use but for pleasure. i think i have a ''feel'' for music it just i have no idea what id need to start learning how to loop/mix etc. ive got virtual DJ. but i cant get my head round how for example this is done (yes i know these mega pros)
http://www.youtube.com/watch?v=3CN6qSsUZwE
are they recording certain parts from the original editing them and then using them over a base backing?
how are they able to turn the whole backing and tone etc instantly  :huh:
alot seem to have a longish build up of quite a fast bassy lead up to the main hit are these pre mixed samples then put together on the live mix? can thsi stuff be done with home laptop software etc
i wont ask much more unless some here knows how to do Doing  :laugh:
any tips and advice on this stuff be great remb i just want to learn and have fun etc
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Seanl
Re: any DJs in here?
« Reply #1 on: 11 May 2013, 18:01 »
Brad (Kells / F17 BAD) is a DJ I think.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #2 on: 11 May 2013, 18:49 »
He is using the Effects on the mixer, which looks like a Pioneer DJM 800 (one of the industry standards)
My advice is get rid of Virtual DJ its sh!te
Get your self a pair of Techncs 1210s and a mixer and learn the art of real mixing first..  Walk before u can run and all that malarky
If you are scared of real vinyl then go for a pair of CD decks, Pionners, CDJ 1000mk3s or newer
any more help just ask, coz yes i am a DJ and a promotor and have had many of the worlds biggest DJs play at my nights
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Toby
  • Car - less
« Reply #3 on: 11 May 2013, 19:07 »
Go for the aiaiai headphones!!
Fools gold!  :cool:
I need to get back in to mixing  :cry:
Currently down under
Offline F17BAD
« Reply #4 on: 11 May 2013, 19:38 »
Fools gold!  :cool:
AiAiAi's are theeee Best    :-0 :cool:
Offline davemk4
« Reply #5 on: 11 May 2013, 20:13 »
Yer will want it cd based. And ye i know the link there is of a beastiegod DJ but id like as you said to learn how to mix 2 tracks together that proberly be a start really. Can i have a tutorial for you lol
Offline davemk4
« Reply #6 on: 11 May 2013, 20:27 »
You seen price of them mk3s lol. I dont wanna spend too much inncase i dont do it lol
Offline F17BAD
« Reply #7 on: 11 May 2013, 23:23 »
Where you live mate ?
Offline davemk4
« Reply #8 on: 12 May 2013, 06:41 »
York pal
Offline Scott D
« Reply #9 on: 12 May 2013, 13:23 »
A cheap and effective setup would be using a DJ controller running either Traktor or Serato software both have very good effects, looping, easy to use and feels close to a hardware CD deck & mixer.
Avoid using the sync features to learn beat matching tho  :wink:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
