Author Topic: white smoke ??  (Read 4124 times)
Offline PATEMANUK
white smoke ??
« on: 09 May 2013, 23:00 »
hi guy for some reason when starting my car up in the morning i get white smoke but when driving about i have none but hen come to a stand still with the engine ticking the white smoke returns i went to a garage and they replaced the wiring loom to the injecters but hasnt sorted it any idears cheers
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: white smoke ??
« Reply #1 on: 09 May 2013, 23:55 »
I think the odd wisp of white smoke in the winter is condensation.
.could be the same for your start up issues...
But not sure on your ticking over issue..
Offline PATEMANUK
Re: white smoke ??
« Reply #2 on: 10 May 2013, 00:02 »
also sometime when driving it shudders ?
Offline scarr89
Re: white smoke ??
« Reply #3 on: 10 May 2013, 10:49 »
Boost leak? Shuddering could be a pipe popping off momentarily.
Offline Rhyso
Re: white smoke ??
« Reply #4 on: 10 May 2013, 14:33 »
Is it a 150? Whats the mileage?
Have the cam and followers been replaced?
EDIT - any of these symptoms apply to you?
http://www.golfgtiforum.co.uk/index.php?topic=140425.0
« Last Edit: 10 May 2013, 15:33 by Rhyso »
Offline M88TOX
Re: white smoke ??
« Reply #5 on: 31 May 2013, 20:43 »
try shell vpower for a bit that will clean it up loads, plus u will get more mpg lol
Offline Agreeable Slick
  • Unit
Re: white smoke ??
« Reply #6 on: 11 June 2013, 13:21 »
I would suspect an iffy injector. White smoke on a diesel usually means unburnt fuel. Either that or get a compression test done, smoke should disappear when engine hits temp.
