Author Topic: MK3 TD Umwelt Clutch Issue.  (Read 2586 times)
Offline Jamesimp
« on: 08 May 2013, 13:03 »
Okay, Problem. Pulled upto a junction, pressed the clutch, there was a clunk, pedal stayed at the floor. Open the bonnet, clutch cable hasnt snapped. and i can move the arm on the gear box easily by hand.... Whats broken....?!?! Engine is a 1.9td AAZ umwelt with standard gearbox (i dont knot the code). Any ideas?
Offline vwwvgolf
Re: MK3 TD Umwelt Clutch Issue.
« Reply #1 on: 08 May 2013, 14:28 »
could be the clip bit where the cable goes to the pedal?
does the pedal move at all or stuck down??
Offline madmanmart
« Reply #2 on: 08 May 2013, 15:25 »
Sounds like the rod has pushed through the pressure plate,
Gearbox off to sort.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline Jamesimp
« Reply #3 on: 08 May 2013, 17:43 »
Pedal and cable are still attached to one another.
when you say the rod has pushed through the pressure plate.... What do i need to replace??
Offline itavaltalainen
« Reply #4 on: 08 May 2013, 17:50 »
you say the cable has snapped?
are you sure it is not just the metal clip that holds the cable in place that has rusted off?
item 30 in image below:
Offline Jamesimp
« Reply #5 on: 08 May 2013, 18:53 »
No cable hast snapped and is still connected at both ends. Pedal is still functional as is acting upon the cable i can get the pedal back into position by pulling the cable at the gearbox end. The arm out the box has bo pressie on it. It should be hard work to pull it by hand but it isn't.
« Reply #6 on: 08 May 2013, 19:04 »
ah yeah.... then probably gearbox off job
« Reply #7 on: 08 May 2013, 22:07 »
Might be the clutch release arm has snapped, can be accessed by removing the small green cover on the end of the gear box.
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 09 May 2013, 00:28 »
Try this before taking gb off. It might have cracked
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 09 May 2013, 09:11 »
it will 100% be the release arm ratchet... they crack and let the pedal drop
luckily they only cost about £15 (but you also need the green cap which is about £5), as wayne said remove the cap and you can just about get to the clip on the clutch arm to remove it. check the ratchet that goes round this and I gaurantee it will be cracked somewhere
you may need to jack the engine on the driver side to get a little bit more room  :wink:
