Author Topic: PCV System Mods + Oil Catch Can  (Read 12726 times)
Offline Jonnybbad
Re: PCV System Mods + Oil Catch Can
« Reply #10 on: 08 May 2013, 17:01 »
On the auq you can get rid of the puck and is the DV even in the right place that ain't where I have mine and I've got a catch can fitted the limp mode maybe due to this
Offline golfyste
  • Project track car
« Reply #11 on: 08 May 2013, 17:40 »
Please explain to me what makes the auq special and why you can remove the puck valve??
The split-r valve is in the correct place and leave the puck where it is.
Do as stated and report back  :smiley:
Offline D@nCeR
« Reply #12 on: 08 May 2013, 18:39 »
250 bhp with no fmic??  :lipsrsealed:
As said get rid of literally everything and be left with a vacuum to the dv and the fpr no need for the reservoir
Also what noise are you getting when the valve dumps? Is it a flutter or a wosssssh as it (the dv) might not be set up properly
I have got FMIC.. And a lot other mods.. Decat full Milltek etc..
I couldn't find any info on removing it all.. I just simplified it..
Maybes I should be looking at removing it all then..
Offline rio_gti
Offline D@nCeR
« Reply #14 on: 08 May 2013, 20:24 »
Offline Jonnybbad
« Reply #15 on: 08 May 2013, 20:52 »
Why don't you enlighten us all as you clearly know it all ?????
I thought the idea of a forum was to give and receive advise but I must be wrong and we all only need to ask you all we need to know
Offline dom
  • Back in a Mk4
« Reply #16 on: 08 May 2013, 21:08 »
To be fair, you asked for advice and he has given you some.
Offline golfyste
  • Project track car
« Reply #17 on: 08 May 2013, 21:12 »
Im sorry but i never said I know it all, in fact I'm far from knowin it all.
Forums are for giving an receiving advice by you shouldn't be giving advice unless your sure its right or if you do you shoul be stating that that is what you think but may be wrong.
The fact is there is no difference for example between the auq and aum that means youcan remove the puck valve on the auq.
The puck valve is designed so that at idle (vacuum) it is open so that gasses can freely flow from the block into the tip but when you put your foot down and create boost it creates a strong vacuum on te inlet side of the turbo which sucks the diaphram down and closes the valve so you don't suck all the gas out of the block and then it reopens again when either pressure is equalised I.e letting off the throttle or when the gasses in the block exceed the vacuum from the tip and it forces the diaphram off its seat to release the excess pressure
So another words your best leaving it on  :smiley:
« Last Edit: 08 May 2013, 21:17 by golfyste »
Offline GTi_James
« Reply #18 on: 08 May 2013, 21:30 »
 :huh:
Offline golfyste
  • Project track car
« Reply #19 on: 08 May 2013, 21:57 »
To D@nCer I have to apologise as I seem to be wrong about the istallation of the split-r as its designed differently to the 007p.
You have it the right way round but I would still change it or a recirc 007 008  :smiley:
