Author Topic: PCV System Mods + Oil Catch Can  (Read 12727 times)
Offline D@nCeR
Re: PCV System Mods + Oil Catch Can
« Reply #20 on: 09 May 2013, 00:51 »
Did you follow this guide??
http://www.golfgtiforum.co.uk/index.php?topic=113646.0
This is the one to use  :wink:
http://forums.vwvortex.com/showthread.php?4893472-DIY-Ultimate-SAI-N249-PCV-EVAP-Delete
So I can delete all the SAI/N249/PCV and leave the EVAP part intact..
resister the plugs and it wont throw any CEL on? how do I go about getting it coded out? Vagcom?
Offline paultownsend
« Reply #21 on: 09 May 2013, 07:57 »
I would delete all the can, including the charcoal canister. Another good source of a boost leak.
I would also plug the tip and vent the catch can under the car.
If you do the above you will reduce the chance of quite a few boost leaks.
And I would also change the split r for the new superceeded Vw OE 710n DV.
The difference it made after changing over a forge 008 was noticeable. I guarantee your forge valve leaks boost.
Offline GTi_James
« Reply #22 on: 09 May 2013, 08:12 »
whats this now? i thought that even the Car Gods swore by the two forge options? how much is the one you stated?
Offline rio_gti
« Reply #23 on: 09 May 2013, 09:22 »
You should have a blank that replaces the trumpet to turn your dv into a recirc one.
Offline D@nCeR
« Reply #24 on: 09 May 2013, 10:56 »
I've tried it blanked off it makes no difference when we boost leak tested it...
Besides I had 0 zero issues before PCV mods.
Offline D@nCeR
« Reply #25 on: 09 May 2013, 18:40 »
Can't find any info on how to turn off or map out the N valves and Sai... Anyone know how to do it.. Don't want CEL coming on at all..
Offline rio_gti
« Reply #26 on: 09 May 2013, 19:08 »
I used the resistors and all is good mate
Offline D@nCeR
« Reply #27 on: 09 May 2013, 23:54 »
awesome mate.. ill start ordering the parts :) thanks for the info
Offline D@nCeR
« Reply #28 on: 11 May 2013, 00:52 »
Just been having a look about at resisters and found this..
http://www.seatcupra.net/forums/showthread.php?t=296476
Is that just 1 guys paranoia or is there truth behind it frying ECU's?
I know minimal shizz about electronics and resistance.. but it makes sense.
Offline jonnyturbo
« Reply #29 on: 12 May 2013, 18:54 »
yerh as said junk all the pcv system its a waste of time
