Author Topic: Engine test - to all you 16Vers - put your results in here >  (Read 1661 times)
Offline Deefadog
  • Mk2 16V (November 89)
Just to check a few discrepancies between my valver and monza's i would appreciate it if you could all note down the speed you are going in each gear at 4.5k revs:
Here is mine:
1st = 20mph
2nd = 40mph
3rd = 60mph
4th = 75mph
5th = 90mph
Thanks
Offline monzablue16v
Re: Engine test - to all you 16Vers - put your results in here >
« Reply #1 on: 05 August 2005, 20:09 »
mine are as follows!
1st = 30mph
2nd = 55mph
3rd = 80mph :)
4th = tba
5th = dunno found a tractor lol
« Last Edit: 05 August 2005, 20:19 by monzablue16v »
Offline TIM20
« Reply #2 on: 05 August 2005, 20:28 »
Sounds like one of you has an 8v box and the other a 16v as i think the ratios are slightly different.  Mine with the standard 16v box are similar to the top set
Tim
Offline Deefadog
« Reply #3 on: 05 August 2005, 20:31 »
I thought something was up :) first i thought he might have 140 clocks :)
« Reply #4 on: 05 August 2005, 20:36 »
LOL It's just feckin rapid it ain't wrong it feels that fast I can't explain it I might capture it on video ;) treck up here and I'll take you out and then  u take me out need to get 1/4 mile time done asap!! edit: need to do it properly without tractors and stuff kinda slows the process down! u got pm deefa
« Last Edit: 05 August 2005, 20:39 by monzablue16v »
« Reply #5 on: 05 August 2005, 20:41 »
Oh and BTW I'm going through the rev range dude not just cruising I only accelerate!!! I can't help it it just happens zooooom  :grin: :grin:
Offline TIM20
« Reply #6 on: 06 August 2005, 06:44 »
Even if your car is fast it will still be doing the same revs in any one particular gear to another car of the same spec.  Just sounds like one is fitted with a 8v box and the other a 16v nothing wrong with either just slightly different ratios leading to the differences each of you are seeing at any point in one particular gear.
Tim
Offline Deefadog
« Reply #7 on: 06 August 2005, 07:11 »
Very true!
If i remeber an 8V box in a 16ver, is the best compromise, as you can have the low down grunt but can cruise on lower revs in 5th, when i am cruising at around 70mph i am on about 3.5k revs, i suspect the Monza would be under 3k revs? i am assuming that it would take you longer to get to 60mph - 100mph than me but quicker to 0mph to 60mph then me?
I am just guessing here i have no idea really :)
Offline TIM20
« Reply #8 on: 06 August 2005, 19:23 »
Thats the one most people swap to an 8v box if they do lots of high speed motorway driving.  The 8v box allows less revs at any one speed than a 16v box in fith.  Think the rest of the ratios are very similar so the o-60 only using first and second will be almost the same and the driver of the car will prob have more to do with it than the gear ratios.
Tim
