Author Topic: GTI rear discs  (Read 2821 times)
Offline macccityrocker
GTI rear discs
« on: 05 May 2013, 19:22 »
Hi folks can someone please tell me are the rear discs on a 1998 gti 8 valve 226mm/10mm? Cheers Steve W..
Offline Gash
Re: GTI rear discs
« Reply #1 on: 05 May 2013, 20:39 »
they all are i believe
Offline tweed
Re: GTI rear discs
« Reply #2 on: 05 May 2013, 20:42 »
Yes they are.
8v gti, 16v gti, and vr6 are all the same.
Re: GTI rear discs
« Reply #3 on: 05 May 2013, 20:48 »
If replacing the rear discs I would recommend new wheel bearings as well.
Offline Leebob
  • Jetta Sport TDI cr170,Mk3 Colour Concept 8v
Re: GTI rear discs
« Reply #4 on: 05 May 2013, 21:27 »
Any reason why wayne?
Gavv8
Re: GTI rear discs
« Reply #5 on: 05 May 2013, 21:35 »
Because you would have to remove the old bearings from the discs to re-fit to the new discs and would probably damage them in the process, new bearings are fairly cheap and mk3's can be quite hard on rear bearings if the pre-load isn't set correctly so all in all its better to change the disc/pads/bearings in one hit for peace of mind.
Re: GTI rear discs
« Reply #6 on: 05 May 2013, 21:37 »
Spot on :afro: sound advice
Gavv8
Re: GTI rear discs
« Reply #7 on: 05 May 2013, 21:47 »
Its also worth mentioning for this job that you will need the caliper rewind tool to compress the pistons back in to the caliper..this is a MUST as you will damage the caliper without it, its also highly likely that the two caliper carrier bracket allen bolts will be a pain to remove so its worth having a good 8mm allen socket that fits in to the bolt properly and even some irwin extractors in case you round the allen bolt out.
Offline Gash
Re: GTI rear discs
« Reply #8 on: 05 May 2013, 22:23 »
carparts4less... £36 delivered for two rear discs and bearings... bought them last week!
Re: GTI rear discs
« Reply #9 on: 06 May 2013, 08:42 »
Thanks for the replies folks.......
