Author Topic: GTI rear discs  (Read 2822 times)
Offline Leebob
  • Jetta Sport TDI cr170,Mk3 Colour Concept 8v
Re: GTI rear discs
« Reply #10 on: 06 May 2013, 10:14 »
Because you would have to remove the old bearings from the discs to re-fit to the new discs and would probably damage them in the process, new bearings are fairly cheap and mk3's can be quite hard on rear bearings if the pre-load isn't set correctly so all in all its better to change the disc/pads/bearings in one hit for peace of mind.
Good to know,il bear this in mind if I ever do mine. :cool:
Offline gasketface
Re: GTI rear discs
« Reply #11 on: 07 May 2013, 21:27 »
Do'nt forget your abs rings if you have abs as not all new discs come with them  :smiley:
Gavv8
Re: GTI rear discs
« Reply #12 on: 07 May 2013, 21:34 »
Take the old ones off and re-use.
