Author Topic: Any Caddy/Inca owners on here?  (Read 1766 times)
Offline SI74
« on: 04 May 2013, 21:10 »
As above looking some info on the axle flip. Already on just caddys but want to post it up on a few sites.
Offline hobbiniho
Re: Any Caddy/Inca owners on here?
« Reply #1 on: 05 May 2013, 16:48 »
i have a mk2 van that has an axle flip but best place to ask is the caddy forum what do you want to know?
Offline lewis1641
  • stuck in the 90's
« Reply #2 on: 11 May 2013, 13:33 »
also done an axle flip. dont believe people when they tell you to just flip the axle lol
also dont believe poeple when they tell you mk3 gti seats "slide straight in"
« Last Edit: 11 May 2013, 13:36 by lewis1641 »
Offline swainy
« Reply #3 on: 11 May 2013, 17:30 »
I've done a axle flip too. Don't own a van tho but my mate does,
Mk3 seats do slot in, bit of a pain to get in but no mods needed. Mk4 seats are deffo worth the extra effort tho.
Offline lewis1641
  • stuck in the 90's
« Reply #4 on: 11 May 2013, 20:16 »
I had to strip mine down, slide in the bases then put the back on in situ.
Offline SI74
« Reply #5 on: 14 May 2013, 22:38 »
Got sorted thanks for the replies lads but is there any other things to do apart from cutting and welding the bracket on again?
I fitted Audi TT seats to mines. Real pain in the ass
Offline lewis1641
  • stuck in the 90's
« Reply #6 on: 15 May 2013, 10:08 »
fit shorter shocks
and blocks under the axle to get it really low!
Offline hobbiniho
« Reply #7 on: 15 May 2013, 17:30 »
i take it you have cut down the compensator bracket aswell?? yeh shorter shocks are a must
Offline SI74
« Reply #8 on: 15 May 2013, 18:18 »
Yea have the shocks on order along with all new bolts.
Must look into cutting down the compensator bracket didnt know it needed work cheers
Offline lewis1641
  • stuck in the 90's
« Reply #9 on: 17 May 2013, 11:20 »
forgot about the bracket! (as i did when i did mine lol)
i removed my bracket, stretched the spring and attached it to the bracket holding the brake lines
