Author Topic: Hub nut removal...  (Read 3582 times)
Offline spikenipple
Hub nut removal...
« on: 03 May 2013, 18:52 »
Any tips?
I've already broken my 3/8" drive bar trying to undo it (Halfords sh!te) so I've got a quality 1/2" drive bar on it with a 3ft tube over it and I still can't get it to budge  :shocked:
I need to change the outer CV boot for the MOT on Tuesday.
Offline madmanmart
Re: Hub nut removal...
« Reply #1 on: 03 May 2013, 18:58 »
Simple really....... bigger bars
Use 3/4" if you have it.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Gavv8
« Reply #2 on: 03 May 2013, 19:37 »
I put a short scaffold bar over the socket extension bar and then jacked it up with the trolley jack, came loose eventually but it took a while.
Offline Len
« Reply #3 on: 03 May 2013, 19:51 »
Oh no! Hope mine isnt that bad!
What size is it? Think I have most of the big sockets.
www.sas.org.uk
www.the-ace.org.uk
Offline itavaltalainen
« Reply #4 on: 03 May 2013, 19:53 »
iirc that nut is tightened up with somewhere round 210nm.... i.e. at 1m distance you need to apply 21kg and that is when just done up... add a little bit of rust, salt,.... 1m pipe and some muscle will get it loose thou.
Offline Len
« Reply #5 on: 03 May 2013, 19:55 »
So my 19 stone should have no problem! :laugh:
www.sas.org.uk
www.the-ace.org.uk
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 03 May 2013, 19:58 »
^^^ love the maths ^^^  :smiley:
Our hub spanner is a meter of 2x1" u channel with the socket welded on the end, nothing can break .
Offline kempie
  • where would we be without duct tape?
« Reply #7 on: 03 May 2013, 19:58 »
Just done it but it was all off the car (hub & dr shaft) and we had 3ft bar and hit it with the hammer
« Reply #8 on: 03 May 2013, 20:11 »
here's some more math for you....  :laugh:
you only got full force for loosening bolts as long as the bar is at horizontal, since gravity only works down. the force exerted on bar will decrease with every degree you go down. so weight alone is not the answer ;)
Offline spikenipple
« Reply #9 on: 03 May 2013, 20:18 »
I've got a 30mm socket 12-point socket on it, with a 5" extension bar (can only do it with the wheel on and the socket doesn't protrude far enough), then a 24" long 1/2" drive breaker bar with a 3ft long tube over it...still won't move before the socket slips off of the nut (awkward as fooook).
