Author Topic: Hub nut removal...  (Read 3596 times)
Offline Len
Re: Hub nut removal...
« Reply #10 on: 03 May 2013, 20:32 »
Your 1/2" breaker bar should have a swivel head???
So surely no need for the extension?
www.sas.org.uk
www.the-ace.org.uk
Offline spikenipple
« Reply #11 on: 03 May 2013, 20:43 »
Yeah it has, but to apply the force the right way the bar needs to be perpendicular to the socket, and the socket isn't deep enough to reach the hub nut without an extension.
Offline Len
« Reply #12 on: 03 May 2013, 20:46 »
Not done this on a Golf yet but have on many other cars without any trouble, so maybe this will be my Nemesis! :shocked:
www.sas.org.uk
www.the-ace.org.uk
Offline vr6D4v3
« Reply #13 on: 03 May 2013, 22:34 »
This is why I love my air tools
Offline spikenipple
« Reply #14 on: 03 May 2013, 23:01 »
I almost invested in an electric powered impact gun rated to 450Nm this month, ran out of funds though.
In other news...
SUCCESS!
Managed to get the fecker off by taking the wheel off, sticking the wheel nuts back on, getting my missus to hold the brake on and undid it with the big bastard 1/2" drive bar!
It deflected too much with the extension bar on so I thought I'd try it like that and it worked. I'll remember this method for next time!
Offline swainy
« Reply #15 on: 03 May 2013, 23:37 »
I invested in one of those electric impact guns, whipped my hub nuts straight off. Only problem i have is that the splines seem to be welded together and no matter how much i hit them with a large hammer they just wont budge.
« Reply #16 on: 03 May 2013, 23:47 »
It is a lot easier and safer to do it with the wheel on and the car on the ground and getting someone to sit in the car with foot on brake.
Good result with getting it undone  :afro:
« Last Edit: 04 May 2013, 21:18 by Wayne »
Offline spikenipple
« Reply #17 on: 04 May 2013, 01:07 »
Wayne  :whistle:
Offline joshstanvw
« Reply #18 on: 06 May 2013, 01:06 »
I did this very task a few weeks ago you will need a big wrench a 30 mm socket a broom and a very long bar first take the wheel off making sure the car is VERY secure then start the engine and wedge the broom between headrest and brake pedal next trick is to grab the big bar and wrench and place in a way that you are pulling upwards not pushing down (unless you are a big lump) I hope this helps anyone
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
