Author Topic: Votex alarm  (Read 2066 times)
Offline Normasnockers
Votex alarm
« on: 03 May 2013, 08:38 »
Hi all can anyone tell me if a Votex alarm system is a factory fit? I am having a few problems with one on my car and when I found the siren buried in the rear quarter it has VAG plugs/wiring into it so not sure if its after market or not? I will upload some pics later today but any advice would be great it also seems to have an immobiliser in the boot which I have nno fob for this is also connected into this votex system, Thanks in advance.
I also have a 79 Escort it only has a couple of sticky pages!!
Offline GTi_James
Re: Votex alarm
« Reply #1 on: 03 May 2013, 08:59 »
thatcham is OEM, dont know about Votex?
Re: Votex alarm
« Reply #2 on: 03 May 2013, 09:15 »
Right well I think I will be removing it by the looks of it the VAG loom is what confused me a bit, Thanks
Offline GOLF-MK3-GTI
Re: Votex alarm
« Reply #3 on: 03 May 2013, 09:49 »
Yes it is, I have a 98 (R) GOLF MK4, It has Votex alarm factory fit. I have 2 fobs, the little immobiliser reset sort of thing, thats connected in the boot. and a code to get the key made.  :grin:
Whats wrong with yours?
Offline GTi_James
Re: Votex alarm
« Reply #4 on: 03 May 2013, 11:04 »
did they bring out the thatcham afterwards?
Offline dom
  • Back in a Mk4
Re: Votex alarm
« Reply #5 on: 03 May 2013, 13:00 »
Thatcham don't actually make alarms, they work with manufacturers to provide a classification/rating system for alarms.
Re: Votex alarm
« Reply #6 on: 03 May 2013, 13:05 »
Mine is draining battery and when car is turned off you can hear the siren crackling away from the wheel arch it has also thrown up a fault code related to the immobiliser which coincidentally I dont have a reset fob or code to obtain one im not sure whether I can get a code?
Re: Votex alarm
« Reply #7 on: 03 May 2013, 13:13 »
P1570 engine start blocked by immobiliser is the code thats showing however the car does start straight away if you charge battery or jump it, another reason i asked about factory fit is there are parts of votex system tucked up with sunroof motor which look very untidy and not factory done lol
