Author Topic: GOT MY GOLF  (Read 1867 times)
Offline jasonpi
GOT MY GOLF
« on: 05 August 2005, 07:54 »
What a bloody trip just got in at 7.30am after leaving 12pm yesterday. what can i say the 16 vavlve is very quick indeed enjoyed the ride back but coz i drove the car so hard i had a slight problem and i am hoping some of you have come accross it before. coming to a round about and the brake pedal goes to the floor :sad: little or no brakes pull over check them out no fluid no stopping power f**k all but notice the engine bays soaking not of oil but brake fluids me thinks.
anyway i start pumping the brake trying to get something then all of the sudden smoke when i press the brake and its coming from the gearbox side :huh: has anyone seen this and is it an easy fix?
sorry if i sound dumb but i need coffee and sleep
Offline kniterider
  • had most, sold most and often buy more!
Re: GOT MY GOLF
« Reply #1 on: 05 August 2005, 08:30 »
jason i think i might be able to shed some light, if you check through all the reciepts etc, i think it had new brake pipes etc for its mot in march, im wondering if one of the unions where they fit to the bulk head has come loose??? i think this is where the problem must be as you describe 'smoke' this must be where when you press the brake pedal a spray of brake fluid its going onto the hot exhaust manifold, hence the smoke.
hopefully it will be a case of tightening it up etc, topping up the fluid and then bleeding the brakes!!!
Gaz
Offline jasonpi
Re: GOT MY GOLF
« Reply #2 on: 05 August 2005, 12:22 »
right put a bottle of brake fluid in just to see and its gone straight through!! in less then 30 seconds if it is the union would it piss out that quick?? help i want to go out and about
Judderi
Re: GOT MY GOLF
« Reply #3 on: 05 August 2005, 15:04 »
You just gotta find the leak 1st mate then ask us and we may be able to help out better.
Offline tobz.
Re: GOT MY GOLF
« Reply #4 on: 05 August 2005, 15:12 »
In the meantime be carful of your paintwork if you've got brake fluid spraying out everywhere! Wouldn't want to ruin some lovely oak green paint ;) (I'm assuming it's Gaz's oakie you bought)
You got any pics of your dad's split ?
Judderi
Re: GOT MY GOLF
« Reply #5 on: 05 August 2005, 15:24 »
As he said clean any paintwork that has brake fluid on as its corrosive.
Offline tobz.
Re: GOT MY GOLF
« Reply #6 on: 05 August 2005, 15:28 »
It might aswell have brake fluid/nitromors on the bottle.
Didn't notice a couple of splashes on the wing of my last 8v when I was bleeding the brakes. Next thing I knew the were loads of little bubbles along the top of the wing, always put something over the wing now.
Re: GOT MY GOLF
« Reply #7 on: 05 August 2005, 16:13 »
Follow all the metal pipes from under the brake servo to where the disapear under the car, might be tricky with all that engine in the way :grin:
Then get underneath and follow them to the front calipers and then the rears, you'll soon find the source of the leak!
Offline jasonpi
Re: GOT MY GOLF
« Reply #8 on: 06 August 2005, 11:02 »
thanx 4 replying guys was a busted brake pipe fixed now :wink:
