Author Topic: boreing blue GTi  (Read 15319 times)
Offline danny_p
boreing blue GTi
« on: 29 April 2013, 00:11 »
so i get a phone call that goes roughly along the lines of,   oi theres a cheep golf GTi for sale spares or repair.
so bimbels off and buys it yesterday  picks it up and drags it back this morning  haveing not really payed all the much attention to what i was buying
officaly it had,
Flat battery
knackerd starter
broken drivers door lock
so here we have some piccys
its blue and dosent start
oh dear
first look at the motor
problems  have found donkey cock resembeling crap
won't be requireing this - yoink
unbelivable levels of suprise  when it turns out the starter is actualy dead like seller claimed  :shocked:
so over cup of tea parts are summed from scowels sport.  YOINK  020 starter  thanking you
all the VW's have gone bar 1.
Offline danny_p
Re: boreing blue GTi
« Reply #1 on: 29 April 2013, 00:24 »
ummmm  tryed starter  engine didn't spin much....
some rummageing later found a 50mm2  lead with some eye;s allready crimped on,  upgraded time
still didn't spin much -   engine is appearing somewhat siezed right now,   anyway  plugs out and load of scaffeze tiped down the holes  that'll kill or cure
so had a look round for some more shnkeyness
and found.........  a knaked caliper
a nasty exhaust
slight sub optimal looking bias valve
and the boot won't open  so wondering if its full of dead hookers
also apart from the space saver and knackerd calper this side looks ok
however this side looks pissed  going to be needing a new stub axel me thinks
alos found some rust but nothing scary  will deal with that later
anyway the scaffeze works and motor now spun  quite enthusiasticly - spraying scaffeze everywhere ah well
put the plugs back in and still won't bloody run tho
Offline danny_p
« Reply #2 on: 29 April 2013, 00:45 »
so listen for fuel pumps nothing.
so the intank pump  get evicted  it din't even get excited when voltage was applyed directly,  fortunaly had a spare lift pump so that went in.
still  main pump not intrested, so for the short term fix to get it going
we'll be putting some wire on here and connecting them to here
24 volts the wrong way up it a few times got the littel bugger pumping,  dosent sond to clever but it's making 3 bar of pressure with plenty of return flow, that'll do on a sunday.
still won't go,     :sad:
so out come the plugs and compression test .........    and another suprise   13.5 bar across the board but can't smell petrol.  so more more citrus fresh gets squired down it's throat,  it sort f runs on this  and lets out some magic smoke
then with a quite inpresssive bang removes the K&N filter from itself.
so off comes the return line to sample the fuel ........
ummm  actualy looks like fanta or cider piss ,  smells more like cired piss tho.   anyay i'll leave the bottel hanging around  will undoughteld be quite funny at a later date,  pumped off 5ltrs of manky fuel into a can,  so the petrol pixies are going to have to play petrol can rulet now  :laugh:  3 cans     2 have super unleaded in , the other may as well be full of piss.
anyways  clean the plugs up and trys again
well it runs now at least,   tho quite a lot of magic smoke is escapeing
ant enjoying the finest volkswagen magic smoke
to much suprise and disapointment the engine after a while did start to retain it's magic smoke  tho it sounds flat and like most of the newness has been extracted but at least now it;s mobile so can drive it in and out the workshop.
now to aquire another motor
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 29 April 2013, 07:11 »
You bouht that back from death then :laugh:
I actually thought hang the f up his either necking that fanta :sick: or the g2 is necking it lol :grin:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline FlashRedThree
  • MK III Flash Red 1.4 SE + MK V DBP 2.0T GTI
« Reply #4 on: 29 April 2013, 16:37 »
Hilarious write up, good job!
Offline Dave_IOW
« Reply #5 on: 29 April 2013, 18:12 »
Good work Mr P :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline JC
  • Back in the North.
« Reply #6 on: 29 April 2013, 19:17 »
 :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
lotta work to get it roadworthy by weekend lad  :whistle:
Offline danny_p
« Reply #7 on: 29 April 2013, 23:19 »
someone may well still neck the "fanta"  as its still sat in the garage looking rather like fanta,   chould help in solveing the mistery of what it actualy is,   makes a crap substitue for petrol tho.
sadly unlikely to have it on the road by then there are a few f**ked bits that may as well progress straight to upgraded bits.    i am NOT buying any 239mm brakeing components
Offline danny_p
« Reply #8 on: 30 April 2013, 23:57 »
misfire found
misfire fixed
waterpumps started leacking - can't say it wasent expected
on the up side at least its running on all cylinders now
has epic digilag tho going to have to poke that with a stick
