Author Topic: Alternator removal help (1.4CL 70Amp Valeo)  (Read 3376 times)
Offline chiefwhosm
« on: 27 April 2013, 11:53 »
Hi,
    I'm trying to get the alternator out of a 1.4, and I've removed the top long bolt, and a shorter bolt that I saw further down which I presume was the right one (since the Haynes manual didn't show the locations) but the alternator won't shift.
I gather from the manual once the bolts are out you just push down to compress the spring tensioner, release the belt and then remove the alternator but currently when I push down nothing seems to happen.
Am I missing something here?
Thanks,
           Chief.
Offline xionsolaris
Re: Alternator removal help (1.4CL 70Amp Valeo)
« Reply #1 on: 27 April 2013, 12:17 »
Once you remove the bolts u need a  pry bar to pry it out i belive its only 2 bolts but they can get stuck in and require some physical effort to remove it
Offline chiefwhosm
« Reply #2 on: 27 April 2013, 12:28 »
Hi,
   Thanks for the reply. I've tried using a 15" spanner as a pry bar and a small pry bar since I thought I'd get enough leverage with that, but even that didn't seem to work. The engine seems to try lifting out of the car before the alternator comes off.
Chief :)
« Last Edit: 27 April 2013, 12:47 by chiefwhosm »
Offline itavaltalainen
« Reply #3 on: 27 April 2013, 21:56 »
Sure you've undone the right bolts? Although can't think what else would be on the same mount.
Shouldn't be this solid... I've never had to use a pry bar!
Offline chiefwhosm
« Reply #4 on: 27 April 2013, 23:28 »
No, I'm not sure at all if I removed the right bolts.
The bolts I found were the long top one, and a quite short one sort of around the mid-point of the aux. belt, underneath the lowest portion of the belt.
I looked at my 1.9D's alternator, and it also had a bolt on the left hand side around the centre, but this isn't there on the 1.4 (though the hole is).
Chief :)
« Reply #5 on: 27 April 2013, 23:37 »
have a look here.....
http://www.golfgtiforum.co.uk/index.php?topic=252627.msg2317542#msg2317542
it's about swapping thermostats on 1.8/2.0 but covers removing alternator and the bolts are marked in the photos
Offline chiefwhosm
« Reply #6 on: 27 April 2013, 23:49 »
Thanks, so I did at least remove the right bolts (or one of them at least if I'm right that the 2nd real bolt to remove was already missing).
I was getting to the stage of wondering whether the holder was all part of some combined unit because of how solid it is.
So... how much damage will a 4 pound lump hammer do to shift this thing?  :smiley:
Chief :)
« Reply #7 on: 28 April 2013, 00:11 »
post photos of the alternator from a bit of a distance and then some from the belt side of alternator (similar to the two first photos in the linked thread) before you hit it with a lump of hammer.
maybe there is something holding it still on.
Offline chiefwhosm
« Reply #8 on: 28 April 2013, 10:33 »
Hi,
   As best as the weather allowed, here's some (not incredibly good) pictures I managed to take:
Chief :)
Offline xionsolaris
« Reply #9 on: 28 April 2013, 10:59 »
Why is the fan belt still on
