Author Topic: Alternator removal help (1.4CL 70Amp Valeo)  (Read 3377 times)
Offline chiefwhosm
Re: Alternator removal help (1.4CL 70Amp Valeo)
« Reply #10 on: 28 April 2013, 11:04 »
Because according to what I've read, you're meant to remove the fan belt by pushing down the alternator to depress the spring tensioner so that you can remove the belt (and then the alternator). The alternator isn't moving at all so I can't get the tension out of the belt.
Offline xionsolaris
« Reply #11 on: 28 April 2013, 11:26 »
Hmm  i cant see why it wont move if all bolts are off maybe it is generally stuck u need to go about this carefully with a pry bar prefered not hammer as with a pry bar u can guage on what is happening instead of club hammering it till something snaps
Offline chiefwhosm
« Reply #12 on: 28 April 2013, 11:54 »
As mentioned already the pry bar didn't work, the engine started rocking before the alternator ever moved. I did wonder (though haven't tried yet) if a thin paint scraper could be knocked into the smallish gap between the holder and alternator on either side in the hope increasing the gap frees it.
But figured it was probably something I was doing wrong, hence the post for help :)
Offline itavaltalainen
« Reply #13 on: 28 April 2013, 12:20 »
put the upper bolt back in , dont tighten it up thou....
tap the bottom of the alternator from underneath towards the back with a small hammer.... or try pushing down with all your weight really hard, then take the belt off... with belt on no surprise you cannot pull it out.
Offline chiefwhosm
« Reply #14 on: 30 April 2013, 22:21 »
Just wanted to say thanks to all who posted.
Try as I might, that alternator just wouldn't budge to allow me to get the belt off, so in the end I resorted to scissors.
The 1.9D alternator that I was also removing once losened/lower bolt removed swung perfectly down releasing the tension as they're meant to, so at least I know the 1.4 was misbehaving.
Chief :)
Offline xionsolaris
« Reply #15 on: 30 April 2013, 22:24 »
No worrys mate so you altenator is some how stuck in the 1.4
Offline chiefwhosm
« Reply #16 on: 30 April 2013, 22:44 »
Was stuck, once the belt was off it pulled off the car ... Eventually. ;-)
