Author Topic: MK3 Golf Estate  (Read 2545 times)
Offline Jamesimp
MK3 Golf Estate
« on: 19 April 2013, 22:35 »
I finally have a golf estate td. I was just wanting to know if hatchback coilovers fit on an estate?
Offline JC
  • Back in the North.
Re: MK3 Golf Estate
« Reply #1 on: 19 April 2013, 22:37 »
been covered a lot so a quick use of the search function will give you an answer I feel  :whistle:
Offline Jamesimp
Re: MK3 Golf Estate
« Reply #2 on: 19 April 2013, 22:55 »
I did a few searches and drew a blank. I've then searched again with the same keywords and its brought up answers. Is there a reason the back setup is different? Is it for weight reasons?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: MK3 Golf Estate
« Reply #3 on: 19 April 2013, 23:06 »
Yeah the rears have a different set up and like you mention I should imagine it's to cope with the extra potential payload in the boot. Been a TD as well it should have a higher spring rate up front as well due to the heavier engine.
Offline Jamesimp
Re: MK3 Golf Estate
« Reply #4 on: 19 April 2013, 23:20 »
So am i gonna need specific td estate coilies? Or just estate ones?
Re: MK3 Golf Estate
« Reply #5 on: 20 April 2013, 09:46 »
You will need them to suit a TD estate
Offline itavaltalainen
Re: MK3 Golf Estate
« Reply #6 on: 20 April 2013, 10:51 »
Wayne's used the best words: need to suit....
You'll probably find estate coil overs that suit Diesels in addition to the "heavier" 4 cyl. petrols 1.8 and 2.0....
Offline CJA321
Re: MK3 Golf Estate
« Reply #7 on: 20 April 2013, 11:07 »
Gotta love a wagon  :cool:
Not that im biased or anything...
Need tdi coilies though bud
Offline Jamesimp
Re: MK3 Golf Estate
« Reply #8 on: 22 April 2013, 18:15 »
I'm confused now. Haha. So what coilovers do i def need. Do i have options? Has anyone got a link to a few? Im wanting to sit it low as possible on g60 steels. Just.need the coilies to do it.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: MK3 Golf Estate
« Reply #9 on: 22 April 2013, 18:17 »
just need coilovers for a Estate
normal hatchback ones wont work for you, well the front will, its the back thats the issue
Not no ordinary GTI....
www.mixcloud.com/kells/
