Author Topic: Secondary air pump removal  (Read 1808 times)
Offline daddy5x
  • any time now milltek cat back remap
« on: 19 April 2013, 11:22 »
Morning all is there a way to remove air pump thats under engine it sometimes sounds like a jet engine .i know it can be tightened up to solve this but id rather take it off altogether thx
standard gti turbo (aum     4 now
Offline Ashmond
  • Money, b!tches And Boost
Re: Secondary air pump removal
« Reply #1 on: 19 April 2013, 12:55 »
You can remove it completely along with the EGR valve but you will need to fabricate or buy the (overly expensive) Forge blanking cap
Offline Dalo Harkin
« Reply #2 on: 19 April 2013, 17:45 »
It is expensive for what it does, but lets be honest so are most 'mods'
make sure you use the right resistors
Offline golfyste
  • Project track car
« Reply #3 on: 19 April 2013, 23:44 »
Very expensive to say you can make one in about 4 minutes  :laugh:
Offline Big-G
« Reply #4 on: 20 April 2013, 00:03 »
Has anyone got the dimensions to make a blanking plate ?
I want to do this but Ideally have the plate made ready to swap over to save time.
Gareth
My Build Thread (Ed38 sorry)
Offline golfyste
  • Project track car
« Reply #5 on: 20 April 2013, 00:04 »
There isn't really dimensions as such  :laugh:
Just remove it draw around it on some metal cut it drill it and away you go  :grin:
Offline dom
  • Back in a Mk4
« Reply #6 on: 20 April 2013, 10:00 »
It's not quite as simple as that is it? I thought the forge one had a recess and o-ring to ensure it seals properly?
Offline golfyste
  • Project track car
« Reply #7 on: 20 April 2013, 13:31 »
Can't remember perfectly but I think I cut it out and used a sealant.
« Reply #8 on: 20 April 2013, 21:58 »
Your right it does have a recess and o ring :smiley:
