Author Topic: agu Launch Control and traction control  (Read 5630 times)
Offline markgti1.8t
« on: 19 April 2013, 01:33 »
can anyone tell me if a agu can get Launch Control and traction control
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline Dave_IOW
Re: agu Launch Control and traction control
« Reply #1 on: 19 April 2013, 19:45 »
Don't think you can have traction control.
Niki did mention he was working on launch for AGU a while ago I think, the other way is a WOTBOX although it seems the general consensus on these is that you need your rods doing to manage.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline markgti1.8t
« Reply #2 on: 19 April 2013, 20:20 »
thanks would like to know more if the aum can handle the Launch Control would the agu not be ok to thought the agu had stronger rods and pistons
Offline golfyste
  • Project track car
« Reply #3 on: 19 April 2013, 22:35 »
Rods are the same
Pistons are forged but don't make a difference really unless your chasing past 400bhp
BUt either way its not these that are the problem, the Agu is me3.8 ecu with cabe throttle whereas the aum etc are me7.5 ecu which are drivebywire therefor the revs can be controlled using the ecu eg launch control  :smiley:
Offline Chris.
« Reply #4 on: 20 April 2013, 18:46 »
AGU is pretty 'dumb' ecu.
Just learn to drive your car properly and you will minimise wheelspin.  Throttle isnt a on/off switch.   I could launch 250bhp AGU k03s without wheelspin slamming it into 2nd from 1st full throttle.
All down to map and how well you can drive.....and tyres.
Click For Build Thread
jamie16v
« Reply #5 on: 22 May 2013, 21:36 »
exactomondo!  :smiley:
Offline Rallye.no1
« Reply #6 on: 22 June 2013, 00:21 »
Rods are not the same. AGU has same rods as 210/225 engines, other 150/180 bhp engines don't.
You are correct about the ECU's though ;-)
« Last Edit: 22 June 2013, 00:23 by Rallye.no1 »
Offline golfyste
  • Project track car
« Reply #7 on: 22 June 2013, 07:49 »
The wrist pin is 20mm yes unlike the aum but for all intensive purposes they are the same as they will all bend about the same sort of power. The 20mm wrist pin rods are no stronger than the 19mm ones.
