Author Topic: climatronic  (Read 2004 times)
Offline mcgee9t2
climatronic
« on: 17 April 2013, 12:39 »
anyone able to clear this up for me.
the e-con button, does this stand for electronic conditioning (or something?) and basically mean air con on?
or does it stand for economical and mean air con off?
keep hearing conflicting stories of whether i have my air con on or air con off.
also ive had a look in the book but couldnt find the section for the climatronic.
Offline GTi_James
Re: climatronic
« Reply #1 on: 17 April 2013, 12:44 »
i think its suppose to work as as an internal temp regulator?
i never use it tbh
Offline Scott D
Re: climatronic
« Reply #2 on: 17 April 2013, 14:48 »
e-con button turns the air con off
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Kelvin1977
Re: climatronic
« Reply #3 on: 19 April 2013, 18:09 »
I always thought it meant economy as in air cooled slowly  :embarrassed: Rather than cooling as quick as pos
Offline navmk4gti
Re: climatronic
« Reply #4 on: 19 April 2013, 20:35 »
When it says "econ" on right hand side means your air con is off.
Offline Hoggy
  • Mk4 GT TDI 150.
Re: climatronic
« Reply #5 on: 19 April 2013, 23:20 »
As above, Air con off, and it sometimes smells..  :laugh:
Offline davemk4
Re: climatronic
« Reply #6 on: 20 April 2013, 07:01 »
Took a while for me to find it in book too as i too needed an answer to this few month back.......
Auto- use air con to regulate the temp displayed using just aircon for warming/cooling
Econ- uses engine warm air and outside air to regulate the temp displayed
Nothing- just like a hot and cold dial just blows warmer/cooler depending on temp selected
Im my opinion i prefer the normal rotary knob version. As the climate control so fiddly. It slow to respond too i find.
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Marktwo8v
Re: climatronic
« Reply #7 on: 20 April 2013, 11:40 »
I have a question about this system too.
You know how in a car with the dials,when you turn the dial completely to cold on start up,you close off the heater matrix etc so that hot water is circulating only in the engine as it warms up.
Well,how do you do the same with Climatronic,any ideas?
Thanks.
Offline Bellend
Re: climatronic
« Reply #8 on: 20 April 2013, 11:47 »
Thanks.
It doesn't on Golfs. Gets me when everyone says "you must have the heating set to hot when bleeding coolant system". Doesn't apply to Golfs as they just have a flap they don't shut the matrix off like Fiestas
Where all my moneys went.
Re: climatronic
« Reply #9 on: 20 April 2013, 21:49 »
Econ is air con off, that is what I was told with the Skoda.
