Author Topic: Help :(  (Read 1597 times)
Offline turbokid23
Help :(
« on: 14 April 2013, 22:48 »
Hi ppl had a funny day when my car is cold on start up it starts to splutter been told it might be a coil pack on the way out revs dip and then pop back up, also fitted a sub and amp now my battery is dead as the amp is stopping on, eney help would be good
Offline dom
  • Back in a Mk4
Re: Help :(
« Reply #1 on: 14 April 2013, 22:50 »
Have you scanned for fault codes?
Offline turbokid23
Re: Help :(
« Reply #2 on: 14 April 2013, 22:53 »
Yeah mate scanned it not 1 fault code so its baffling me
Offline GTi_James
Re: Help :(
« Reply #3 on: 15 April 2013, 08:34 »
uprate your battery as you should do with any mods that require extra power, i had this issue with a double din headunit, new battery sorted it out no problems
Offline Jin_C
Re: Help :(
« Reply #4 on: 15 April 2013, 09:39 »
Update the battery? The alternator powers the electrics once the car is on. Although change the battery if it is on its way out.
Make sure the remote wire from the head unit is connected to the amp properly.
Then I would check which power connection is being used for the head unit. One will keep the head unit powered while the car is off and the other will only power it when the keys are in the ignition.
« Last Edit: 15 April 2013, 09:44 by Jin_C »
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline GTi_James
Re: Help :(
« Reply #5 on: 15 April 2013, 09:44 »
no "uprate" if the battery tests in the 50% marks and only short journeys are used your not getting a full charge and as a result the battery is used more often than not, as said i changed my battery and it works 100% better
Offline Bellend
Re: Help :(
« Reply #6 on: 15 April 2013, 09:47 »
Remote lead in amp incorrectly fitted? Leaving amp on at all times?
Could well be a coil. Hard to diagnose over the internet though. Could even be a temp sensor, throttle body needing a clean etc.
Clio I bought to sell was doing exactly this and just needed a throttle clean as wasn't quite letting enough air past when cold. Was fine when warm though and was spot on after a clean. Try free things first. Best bet would be to pay for a diagnosis though.
Where all my moneys went.
Offline turbokid23
Re: Help :(
« Reply #7 on: 15 April 2013, 10:01 »
It's had new temp sensor and thermostat, that's y I think coil
Offline Dalo Harkin
Re: Help :(
« Reply #8 on: 15 April 2013, 12:26 »
the revs dipping could be related to the battery, most places will test the battery for free, so get it tested.
Next as mentioned I would try unplugging the electrical connection on the MAF and see if that's any better, then move onto other things
Offline xionsolaris
Re: Help :(
« Reply #9 on: 16 April 2013, 06:35 »
revs dipping dont forget the more power you use the more strain on the altenator to deal with the current load
