Author Topic: Forge TIP has landed ...... Few questions again  (Read 4134 times)
Offline AD1.8T
Re: Forge TIP has landed ...... Few questions again
« Reply #20 on: 12 April 2013, 09:29 »
Right first off dodgy maf fitment
Now the new recirc location usually as you know this is under the cover so quite an extreme movement !
Offline Felton
« Reply #21 on: 12 April 2013, 14:13 »
Your recirc is on the wrong way round ent it mate ? Mine goes the other way
Offline AD1.8T
« Reply #22 on: 12 April 2013, 14:20 »
As far as im aware the only difference it makes is in the noise i ran it this way as before the vac pipe on the top was getting squished by the cover which caused problems, supose theres no excuse to put it the 'normal' way now though lol
Offline dom
  • Back in a Mk4
Offline Dalo Harkin
« Reply #24 on: 12 April 2013, 21:18 »
I think when the DV is the "wrong" way it makes a horrendous chirp noise  :sick:
Offline AD1.8T
« Reply #25 on: 12 April 2013, 21:40 »
Everyone mentions that but mine makes more of a chirp the normal way as it is now it makes a nice ... Wtttsssshhhhh???
Offline Nino
« Reply #26 on: 12 April 2013, 22:02 »
Taken from a thread on Vortex:
http://forums.vwvortex.com/showthread.php?5706249-diverter-valve-position
Just reading that topic. This is very interesting. I have had a 17705 for a long time and I have changed almost everything I can think of. I wonder if I tired the reverse like AD1.8T if it would be any different.
Current - MK6 GTi Edition 35
Offline AD1.8T
« Reply #27 on: 12 April 2013, 22:38 »
Do you use your engine cover ? When i had mine the other way the top vac pip was getting bent so no air could go through (like kinking a hose) and it made the turbo stall ever so slight and brought up the above code ! Worth a try or even just wip off the cover !
Offline Nino
« Reply #28 on: 12 April 2013, 22:41 »
Nope prefer the look without it haven't used my cover for about 5 months. I have changed a heel of a lot too only thing I haven't dne is a catch can and n249 bypass but all hoses are now silicone and I got forge 007p and just put a brand new n75 "E" on
Offline AD1.8T
« Reply #29 on: 12 April 2013, 22:42 »
Agu charge pipe maybe ?
