Author Topic: Forge TIP has landed ...... Few questions again  (Read 4135 times)
Offline Nino
Re: Forge TIP has landed ...... Few questions again
« Reply #30 on: 12 April 2013, 22:47 »
Agu charge pipe maybe ?
Yip done that too :)
Current - MK6 GTi Edition 35
Offline AD1.8T
« Reply #31 on: 13 April 2013, 09:53 »
Just re read what you wrote i didnt notice you said you havent done the n249 bypass..... For the sake of a couple of meters of hose id start there mate as it controls the dv so if faulty will bring up that code. Ive been lucky with my golf tbf for peace of mind and to avoid sudden panic when things go wrong i sorted most of the common faults before they had chance to plan a attack lol! Only things left are the agu charge pipe and catch can :D
Offline Nino
« Reply #32 on: 13 April 2013, 12:13 »
Im not a fan of deletes thou. Im a strong beleaver in "its there for a reason" however i suppose i could have a faulty n249 they cost much to replace?
Offline Dalo Harkin
« Reply #33 on: 13 April 2013, 12:23 »
Yes they are there for a reason, the way in which VW made the car from standard, when you start modifying bits and pieces those specifications change, I have the majority of the deletes done and I can honestly say the difference is noticeable, my garage is full of bits that have been ripped off the golf  :kiss: :grin:
Offline AD1.8T
« Reply #34 on: 13 April 2013, 12:37 »
I wouldnt replace it mate try the bypass first if you dont like it then you can put it back to normal with a new valve
Offline Nino
« Reply #35 on: 13 April 2013, 12:47 »
Hmmmm got me thinking now lol
Offline davemk4
« Reply #36 on: 13 April 2013, 18:52 »
N249 bypass transformed the way my aum drove. The dv is defo wrong and if you read up on this on here, vortex etc it not reccomemded can cause all sorts of issues. I spoke to forge few week back they said it would work in reverse but sound odd(which it does) and could cause boosting issues and all sorts.
I ran a longer dv pipe to top so it tooked under the cover. Been fine
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Nino
« Reply #37 on: 14 April 2013, 09:53 »
Right then if I can get my head around the n249 bypass I'll get onit
Offline Dalo Harkin
« Reply #38 on: 14 April 2013, 10:38 »
If you are doing it for diagnostic purposes only then do the bypass, but I would still recommend the delete over the bypass, because as stated before the bypass is hit and miss
Offline davemk4
« Reply #39 on: 14 April 2013, 11:08 »
I dont quite get the difference to by pass to delete? My n249 valve still attached to loom etc but no pipes on so is this a bypass and with resistor is delete?
