Author Topic: Anyone else got a Clifford concept 50 Alarm installed?  (Read 4203 times)
Offline Deefadog
  • Mk2 16V (November 89)
If you have, i just want to compare notes, as i have a problem programing it using the feature select option and want to see if i am doing it wrong or there is a fault somewhere!
Offline Martz
Re: Anyone else got a Clifford concept 50 Alarm installed?
« Reply #1 on: 03 August 2005, 10:11 »
I have on mine. Not sure how to use. May just get it ripped out and get another installed.
What are they like anyway?
Offline Deefadog
« Reply #2 on: 03 August 2005, 10:42 »
It seems really good, no false alarms or anything like that!
here is the owners manual if you don't have one - http://www.clifford.com/guides/ogs/concept50uk_owners.pdf
The problem i have is that i don't have a cherp sound, there is an option to disable this, but when i try and turn it back on it does not seem to work!
If you your vallet code (you should) this is what you do:
enter vallet code (e.g 1-2-3) -
Flip latch down once
flip it up and back to center
Flip latch down twice
Flip latch down three times
flip it up
(you are now in your vallet mode/ alarm disabled)
imediaetly hold down the switch for 3 secs and release and you should be in feature select mode.
hit the switch 5 times down and this should turn the cherps on or off!
does it work for you?
Offline Martz
« Reply #3 on: 03 August 2005, 11:03 »
Mine doesn't chirp, but I will try that.
Offline Deefadog
« Reply #4 on: 03 August 2005, 11:54 »
Cheers!
let me know!
Offline Deefadog
« Reply #5 on: 04 August 2005, 08:58 »
Did you try it Martz?
Offline Martz
« Reply #6 on: 04 August 2005, 10:05 »
I need to buy a new remote. Mine works but has no case. I will when I get a replacement. :wink:
Offline Deefadog
« Reply #7 on: 04 August 2005, 12:44 »
Cheers!
PM me when you ;)
Offline monzablue16v
« Reply #8 on: 04 August 2005, 14:25 »
A Clifford won't chirp if your backup siren battery has gone flat I know my concept 300 needs a new battery u can replace them but it's a bit of a P.I.T.A usually fail after a few years but they are really good alrms.
Offline Deefadog
« Reply #9 on: 04 August 2005, 14:57 »
That could explain it!
The only time it has chirped is when i have disconnected or reconnected the battery!
Where is the battery? in the siren housing? and how do you replace it and from where?
