Author Topic: boomy noise  (Read 4049 times)
Andy76
boomy noise
« on: 09 April 2013, 20:09 »
Probably not the best description but around 45-50 mph I get a boomy noise. It comes from rear of car, almost like its coming from in the boot.
Its always at same speed when cruising, gear/revs and road surface make no difference, tyre tread is good (Bridgestones on standard Gti alloys).
If it was an older car i would suspect a wheel bearing but not sure if this noise is just a common thing/feature of a golf. Are wheel bearings prone to failure?
It needs to go back to dealer in coming weeks but after a month of ownership its a feature that is becoming a real annoyance. Would appreciate any thoughts
ps- its definitely not the stereo!  :wink:
Offline Jimble
Re: boomy noise
« Reply #1 on: 09 April 2013, 20:29 »
Tis a common problem with the mk5 and 6, it's caused by uneven wear on the inside of the rear tyres, also known as sawtooth effect or feathering, it's due to incorrect allignment sometimes from the factory but can also be caused by bumps curbs etc tends to get worse as the tyres get older, mines getting it a little now with 15k miles on the rears.
Like this:
[font=.HelveticaNeueUI]http://www.pistonheads.com/gassing/topic.asp?h=28&t=1242766&mid=0&nmt=Golf+Mk5+rear+tyre+%22saw-tooth%22+wear%2Fnoise[/font]
« Last Edit: 09 April 2013, 20:31 by Jimble »
Offline ajmoir36
Re: boomy noise
« Reply #2 on: 09 April 2013, 20:32 »
Like this:
+1 Tyres.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Andy76
Re: boomy noise
« Reply #3 on: 09 April 2013, 20:39 »
Ok i will have a closer look at the tyres. Its at about 18.5k
I will mention it when it goes in in a week or two for some warranty work, given i've only had it a month the dealer may be helpful
cheers
Offline Jimble
Re: boomy noise
« Reply #4 on: 09 April 2013, 20:44 »
I was quoted £49 for a 4 wheel alignment at the dealers, might be worth asking?
Offline Hartside
Re: boomy noise
« Reply #5 on: 09 April 2013, 20:54 »
Is the alignment on the back wheels adjustable on the GTI?
Carbon Grey 5dr GTI
Offline ajmoir36
Re: boomy noise
« Reply #6 on: 09 April 2013, 21:05 »
Bargain they wanted a £100 off me I refused.
Andy76
Re: boomy noise
« Reply #7 on: 09 April 2013, 21:08 »
I will probably mention to them and let them diagnose it, dependant on the outcome I will push for them to correct it given I have only had the car for a short time.
Will report back in a week or two
Offline Booth11
Re: boomy noise
« Reply #8 on: 09 April 2013, 21:33 »
That's a big difference in cost.  I'm considering getting my wheels aligned, potholes round here are abysmal and pretty sure they've taken their toll on the wheels over the winter.  Wonder what price my local dealer will pluck out of the air, and what exactly are you getting for the money?  :huh:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Raffe
Re: boomy noise
« Reply #9 on: 09 April 2013, 21:36 »
Had mine carried out on a Hunter 4 wheel laser alignment machine for £65, £100 sounds expensive.
