Author Topic: 8v gti headlight adjust  (Read 1066 times)
Offline dan_thevdub_man
« on: 07 April 2013, 22:02 »
iv recently brought the headlight adjust loom and controls. anyone know what else i need for it to work. will it work on the standard lights or are there specific ones
Offline itavaltalainen
Re: 8v gti headlight adjust
« Reply #1 on: 07 April 2013, 22:14 »
you need a light switch with height adjustment wheel, the loom obviously....
and the 2 stepper motors on the headlights. they replace the corner mount of the reflector (the reflector is held on by 3 points, 2 come with adjustment screws, third is a plug with ball end that mounts to reflector - or a stepper motor if it is one with electric height adjustment.
you can convert any oem mk3 headlight with the stepper motor in place of the third mount...
(tbh i don't understand why you'd want it - be happy if you don't have it - one MOT failure mode less ;) )
« Reply #2 on: 07 April 2013, 22:18 »
yeh true i geuss. although car is in garage now having mot so wudnt be installing it until after anyway ;)
