Author Topic: Mk3 Golf Rear Shock removal.....need some ideas....  (Read 2069 times)
Offline MereKat
Can get one off fine, but the Nut inside the rear beam on the other is turning in its bracket...
What can i try to get it undone? Not much space in there to get a spanner into, and cant get enough leverage on a big flat screwdriver to try and hold it still.....
EDIT: This nut
« Last Edit: 07 April 2013, 13:29 by MereKat »
Offline tweed
Re: Mk3 Golf Rear Shock removal.....need some ideas....
« Reply #1 on: 07 April 2013, 14:13 »
Spray it with loads of plus gas or heat up the nut then undo the bolt with a impact gun
Offline danmusic24
« Reply #2 on: 07 April 2013, 14:17 »
Snap the clip off and put a spanner on nut
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #3 on: 07 April 2013, 14:24 »
Like said remove the clip and get a spanner on it. Its the only way.
Offline kempie
  • where would we be without duct tape?
« Reply #4 on: 08 April 2013, 21:20 »
long nose pliers? gonna be a c*nt but only other thing that no ones has said?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 08 April 2013, 22:06 »
Reciprocating saw or oxy-acetylene?
analogue_rogue
« Reply #6 on: 09 April 2013, 05:42 »
weld nut to bracket with a large spot weld.. and turn while nut still hot.... if a spanner doesnt work obviously!
« Last Edit: 10 April 2013, 08:39 by analogue_rogue »
Offline Bellend
« Reply #7 on: 09 April 2013, 10:58 »
I've always used a spanner....
Where all my moneys went.
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 09 April 2013, 18:50 »
This or plasma  :grin:
Offline ttelracs
  • The Fettler
« Reply #9 on: 09 April 2013, 22:19 »
I've always used a ring spanner too, 17 or 18mm I think.
