Author Topic: mk5 rcd510 install/coding??  (Read 2488 times)
Offline R5MEE
« on: 07 April 2013, 11:56 »
 About to install rcd510 with glove box MDI.
 Will a fault code arise? Does the 510 need to be coded?:kiss: cheers for any help
Offline Ginge 35Edition
Re: mk5 rcd510 install/coding??
« Reply #1 on: 10 April 2013, 19:57 »
You should just need the security code which ideally came with the head unit.
Offline R5MEE
« Reply #2 on: 10 April 2013, 20:19 »
Thanks  Ive got it installed and working well. DAB reception is not the best as I only have the basic glass mounted antenna.
 Only receiving around 12 dab stations which are clear and don't lose signal strength.
  I did a rescan when out and about and more stations were showing but only for a short time.
 well pleased with the ipod connection. USB and SD cards are poorer quality than the ipod so wont be using them
 Tempted to get a "proper antenna through the roof :smiley:
