Author Topic: ABS sensor problem  (Read 853 times)
Offline noelmm
ABS sensor problem
« on: 07 April 2013, 09:14 »
 Hi Everyone,
My ABS light and traction control light came on last week so I scanned it and it showed rear passenger sensor had failed so I ordered a new part which came a couple of days ago.
Today I went to remove the old sensor and fit the new one and that's where the problem arose, I couldn't remove the old sensor, the 5mm bolt that secures the sensor  is seized into place, I spryed some wd40 and left it soak but still can't get the bolt out, the socket will not fully sit into the bolt head and if I use an Allan key I can't really get the leverage to loosen it.
Any suggestions??
Thanks
Noel
Offline xionsolaris
Re: ABS sensor problem
« Reply #1 on: 07 April 2013, 10:21 »
Can u fit a set of locking pliers on top of the bolt then lock them and turn the bolt
Offline navmk4gti
« Reply #2 on: 07 April 2013, 12:20 »
Its a b1tch to get out mate you will have to use a lot of force.. pair chunky pliers will be the tool to use :wink:
Offline noelmm
« Reply #3 on: 07 April 2013, 14:34 »
Chunky pliers didn't do the trick.  I'll have to get a pair of locking pliers and give that a go and keep my fingers crossed.
