Author Topic: Pulled my lower back!!  (Read 2897 times)
Offline dTEA
  • back in an MK5
Re: Pulled my lower back!!
« Reply #10 on: 09 April 2013, 20:28 »
^coming from the man who tells him to spend money. And says an osteopath will sort it. :grin:
Edition 30 / T5 T32 Kombi
Offline Guy
« Reply #11 on: 09 April 2013, 21:13 »
 :huh:  they will
Offline Kerrse
« Reply #12 on: 10 April 2013, 13:53 »
Resting it will do nothing but cease it up even more, i had a slipped disc when i was younger & have always had to be a little careful with my back but when it goes i try keep moving as it passes after a couple days.
Osteopath's are good in emergencies although cost a fortune !
Offline james2
  • No scammers please.
« Reply #13 on: 11 April 2013, 21:15 »
i did my back in few years ago leaning under shelves pulling 25kg bags out to make a pile of 56 . Id been working there for over half a year before it happened and moving over 300+ aday. God the pain. If i tryed running i would of past out, getting out the car after work was a killer. I carryed on working in pain and after 2 weeks it was better. Using it is the fastest way of it getting better.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Guy
« Reply #14 on: 11 April 2013, 21:46 »
yes... but well worth it if you can't walk or earn money!  usually about £40-£45
Offline Guy
« Reply #15 on: 11 April 2013, 21:47 »
or possibly exacerbating the problem  :lipsrsealed:
Offline JC
  • Back in the North.
« Reply #16 on: 11 April 2013, 21:49 »
go see a doctor and get proper qualified help
or
end up in need of an op with only a 60/40 chance and live a restricted life because of it.
Offline AudiA8Quattro
« Reply #17 on: 11 April 2013, 21:52 »
Doctor won't do anything unless you are really knackered, they will just tell you to take pain killers.
If you are that bad then worth a go, you will need to be persistant if you want anything done.
« Reply #18 on: 11 April 2013, 21:55 »
Osteopaths can be good, but cost a fortune. Private treatment, depends if you money to burn..
Offline damien010685
« Reply #19 on: 11 April 2013, 23:28 »
Yes but a Doctor can refer you to a specialist which i ended with And has Solved my back problem
