Author Topic: S3 arb  (Read 1744 times)
Offline Felton
S3 arb
« on: 05 April 2013, 23:49 »
Hi guys I've recently fitted my front coil overs and yes got the rub on the drivers side driveshaft so went out and got a s3 arb my question is it doesn't look rite to me has anyone got a pic of what they are like I haven't fitted it yet so want to make sure it is rite cheers fella :)
Offline SI74
Re: S3 arb
« Reply #1 on: 06 April 2013, 06:40 »
Fire up a picture of the one you have and somone on here will know straight away.
Offline Felton
Re: S3 arb
« Reply #2 on: 06 April 2013, 10:01 »
Will get one in a sec and post it up :)
Offline Felton
Re: S3 arb
« Reply #3 on: 06 April 2013, 11:18 »
Ok guys for some reason my imageshack won't let me up load a pic so carnt get one at the sec :(
Offline Felton
Re: S3 arb
« Reply #4 on: 06 April 2013, 11:26 »
Rite here we go guys is this the front ???
http://imageshack.us/a/img811/9139/photoapr06102108.jpg
Offline SI74
Re: S3 arb
« Reply #5 on: 06 April 2013, 12:27 »
Looks like one to me. Why do you think it's not right? They are not as long as a standard one because of the way they are fitted to the car with drop links. You'll need to make up a spacer to get it to bolt up to the standard wishbone.
Offline Felton
Re: S3 arb
« Reply #6 on: 06 April 2013, 14:33 »
Can I not use the adjustable drop links on it mate and I wernt sure as never seen one before and wanted to check mate cheers for your help mate
Offline golfyste
  • Project track car
Re: S3 arb
« Reply #7 on: 06 April 2013, 16:01 »
What coil overs have you got?
Offline GTi_James
Re: S3 arb
« Reply #8 on: 06 April 2013, 16:35 »
and why didnt you go for the TT arb as its a straight swap with drop links
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: S3 arb
« Reply #9 on: 06 April 2013, 16:48 »
TT and S3 ARB are the same.
Use adjustable drop links and knock the centre out of your standard drop link bush, this will give you a spacer which is a perfect fit
