Author Topic: Brake discs/pads  (Read 7045 times)
Offline xionsolaris
Re: Brake discs/pads
« Reply #20 on: 05 April 2013, 23:04 »
U dont need vagcom when i changed my abs pump and bleed my abs i had my car connected to vag com and tried the bleed setting nothing happend but newer vag cars eg mk4 golf need bleeding through vag com
Offline GOLF-MK3-GTI
« Reply #21 on: 05 April 2013, 23:08 »
If you get new rear discs make sure you get the abs rings too and may as well get new rear bearings and races.
 :wink:
what is this? lol
« Reply #22 on: 05 April 2013, 23:10 »
Cheers mate, good to hear  :wink:
Offline sharki786
  • GOT BOOST??
« Reply #23 on: 05 April 2013, 23:26 »
 :wink:
what is this? lol
Simple terms its a ring that comes with the bearing kit.
I have a new bearing in 1 disc last time i had my discs changed they used same bearing (diff garage) il see if i need new bearings if i do il just buy some
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #24 on: 05 April 2013, 23:33 »
 :wink:
what is this? lol
 :wink:
« Reply #25 on: 06 April 2013, 08:10 »
Before I go to order rear wheel bearings, abs rings. shall I also get rear wheel abs sensors too?
Also don't abs rings come with new discs?
Offline xionsolaris
« Reply #26 on: 06 April 2013, 09:12 »
Erm not to sure on that one but one thing make sure u fit the abs ring round the right way as alot of cars allow u to put it upside down and then abs light comes on and you will have to strip the rear again just check the rear sensor clean any metal fillings on the sensor
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #27 on: 06 April 2013, 10:50 »
The ABS rings are sold separately and can only be fitted one way.
Offline xionsolaris
« Reply #28 on: 06 April 2013, 11:18 »
ah i havent changed mine yet but i know on other cars people make that mistake
VW BUSH
« Reply #29 on: 06 April 2013, 14:52 »
if you are careful you can re use the rings, just need to get them off without bending them.
Carefully close them up with long nose pliers a fraction if they are loose on the new disc.
I have a set on the shelf, never needed them on the last three golfs
